Alright, so I guess I'll just start from the beginning, including some history under the previous owner.
This is my 2002 M3 Dinan S2 that I officially bought on May 22, 2017. I bought this off a fellow M3F forum member and friend of mine, Bray. Interestingly enough I actually found this on craigslist for him. He had purchased it in I want to say either 2014 or 2015 from a dealer in Fresno. Was a 2 owner all CA car, clean title, 142k miles, SMG, and had the full Dinan S2 package as well, even down to the Dinan floormats.
Unfortunately, his very in-depth ownership journal (along with mine) went down with M3F so I don't have a ton of photos under his ownership. I'll upload what I have since I uploaded the more important bits onto VinWiki.
As he picked it up, before his usual huge process of cleaning, refurbishing, and replacing parts.
Titan silver over black, SMG, some terribly done subwoofer install, Dinan goodies, etc. Under a layer of crud and dirt was a pretty good condition car, aside from corded tires and common trim wear.
Next few are slightly lower resolution as they're taken from VinWiki.
Dash components cleaned up.
Headlights got a complete teardown with new lenses and gaskets.
New OE chrome kidneys and roundel as well.
New sidemarkers.
New windshield cowl installed.
A-pillars were bunching so they were replaced.
Rear view mirror was replaced as well.
New soft touch
Engine bay detailed and front end reassembled. All cooling hoses were replaced, oil cooler flushed and cleaned up, Dinan strut bar refreshed, all new OEM pulleys, tensioners, and belts, OE BMW oil change, and an OEM fuel filter somewhere in there.
Interior detailed. Seats were fully removed and degreased, then the carpet was heat extracted.
New armrest delete center console with euro sliding tray
Dinan airbox was cleaned up along with a new Dinan air filter.
All underside plastics and panels were removed and detailed. Soaked in gasoline and scrubbed then cleaned with Simple Green.
New OE M3 floormats.
Front and rear wheel wells fully detailed along with refreshed calipers.
The rear Dinan bar was refreshed and Subwoofer removed along with all the wiring reintegrated. Whatever idiot installed it cut half the freaking harness apart.
Car finally back on the ground after a solid month. Bray is incredibly meticulous with everything, so the e46 looked almost new inside and out.
Dinan wheels were sold off and replaced with new hyper silver Apex Arc 8s plus new Michelin PSS.
New CSF radiator was installed at some point. Ended up being defective.
Dinan 3.91 diff was replaced with a stock 3.62. Stock unit was torn down and refreshed, including new bolts and finned diff cover.
Window seals being replaced.
Vanos rebuild. My car got a Beisan seal kit, Beisan redrilled disk, Bray's rattle fix, new OE upper chain guide, OE vanos gasket, new OE exhaust hub w/ cryo treatment, and refurbished cam gears. I believe a valve adjustment was also performed.
Rear parcel shelf was redyded.
The defective CSF unit was replaced with a new OE unit.
Decent sized parts pile accumulated.
Brand new OE LED taillights were purchased and retrofitted.
PO also had a set of Imola Z4M seats in for a bit.
Dinan throttle bodies before a cleaning.
SMG to 6MT conversion being done.
All SMG related wiring was removed from engine bay.
Wiring loom rewrapped and zip tied into original position.
Clutch pedal in.
New CSB and giubo.
Cutout made for the manual shifter, resprayed with a factory matching coating.
Lolipops were bead blasted with new FCABs also installed.
New LUK clutch kit.
New throwout bearing among other things.
Steering giubo needed to be replaced and one of the motor mounts had actually collapsed. New parts were installed.
New RTABs being installed.
Manual cluster insert being installed. Bray usually sells these on his website.
F10 M5 knob wired in.
Cluster back in place.
And everything back together! Worklist included new motor mounts, Rogue transmission mounts, e60 shift lever, F10 M5 knob, OE selector rod, OE aluminum joint, Rogue clutch pedal bushings, Rogue shifter carrier oval bushings, new steering giubo, new driveline giubo, new CSB, new FCABs, manual airbox, manual cluster insert, and ECU flash from SMG to manual.
Rod bearing replacement at 162k-ish miles.
These are actually the second set of bearings. The original ones were replaced under the service bulletin at around 32k miles.
New oil level sensor installed as well.
And here are the last few pics under his ownership.
Had a minty M Texture interior along with brand new Titan Shadow trim, that I, unfortunately, could not afford
New sidemarkers.
New soft touch
Clutch pedal in.
New CSB and giubo.
New LUK clutch kit.
