MSx70 Flasher - Alpha
    Originally posted by Don Fipsi View Post
    I´m back doing some testing with a sparepart ECU on a rough bench flash setup with alligator crimps etc. (might not have the best connection). So far I can only identify the ECU. But when I try to read the flash I only get 0kb bin files. The read out only takes about 5 seconds and there is no progress on the green bar. Then suddenly the window for the saving path pops up. Not sure if it´s because of the bench setup or because of the specific software/program of the ECU. I can read the ECU with INPA as well with out problems in the bench setup. Can´t test the spareparts ECU in my car or my main ECU on the bench because my car is a few hundret kilometers away at the moment...
    Any expirience with program 740S software 0AA2S?
    Try to flash it with WinKFP?
      For those of you having it fail when trying to flash RSA bypass, just use the files from bimmerlab and flash it with winkfp. Once done, use MSV70 flasher to write the tune portion. It worked for me.
        Hello, sorry to post here but i can't send a message
        I have a request for you, could you please calculate the signature of MANSP2 - 9195746A.0pa The signature is at ce0400...
        Or any way to authenticate ecu?
        Thanks Zdenek
          Hi every one need some help here msv70 n52b25 e90 want to turn of downstream o2 sensors cuz i have 29f4 and 29f5 catalyst conversion codes i have tuner pro and xdf file from ms4x wiki for the msv 70 already have a full read of the ecu just need some tutorial how to disable it. Thanks in advance
