ZHP rack coding
    ZHP rack coding
    I have M-Track mode coded I remember when doing so I set it up for my green tag rack. If I go to a ZHP rack what value or "wert" should I be using? Thanks.
    It's currently set to "wert_05" under "LENKWINKELKENNLINIE_2" in the MK60 module.
    Edit: It's "wert_04", found it searching around, thanks heinzboehmer.
    Use the ZCP rack setting. The ratio ends up being the same when connected to M3 spindles.
    2003 E46 M3 TiAg/Cinnamon 6MT
    2005 E46 330i ZHP Imola/Sand
    Instagram:@thegenius46m
      Which is....?
        I *MAY* have taken note as to which setting it was when M-track mode was programmed before I changed it, but the value would be nice.
        Also, on another note aren't the ZCP and ZHP different ratios?
          The actual ZCP and zhp cars have different ratios, but the racks have the same travel for each turn of the pinion. The suspension geometry differences between the M and non-M make the rest of the difference.
            Comes down to the lever arm ratio on the knuckles. I own a zhp sedan and have a low mile zhp rack in the m3 and the sedan steering is noticeably faster.
              Which is....?
              Set LENKWINKELKENNLINIE_2 to wert_04 for ZCP or ZHP steering rack. Either rack installed onto an M3 is a calculated 14.5 steering ratio so the steering angle sensor will not complain.
                I wasn't aware if the the MK60 cars need the yellow tag coded? Or is it plug and play?
                Current:
                  No, it'd still need it. Only ZCP wouldn't, but why would you swap yellow for blue?
                  That said, I have mk60 and yellow tag, with no coding, and DSC only intervenes in spirited driving where I would have DSC off anyway.
                    Only a real ZCP car would not need it coded but honestly the ZHP rack is a complete waste on those cars unless the ZCP rack develops play and needs to be replaced since new isn’t really an option.
