This is a good for anyone and I will be storing it here.
5D90 | Wheel speed sensor (front left) electrical failure |
5D91 | Wheel speed sensor (front left) plausibility at speed > 40km/h |
5D92 | Wheel speed sensor pulse wheel (front left) plausibility tooth fault every wheel revolution |
5D93 | Wheel speed sensor (front left) plausibility at speed < 20km/h |
5D94 | Wheel speed sensor (front left) plausibility during ABS regulation |
5DA0 | Wheel speed sensor (front right) electrical failure |
5DA1 | Wheel speed sensor (front right) plausibility at speed > 40km/h |
5DA2 | Wheel speed sensor pulse wheel (front right) plausibility tooth fault every wheel revolution |
5DA3 | Wheel speed sensor (front right) run-up plausibility detection |
5DA4 | Wheel speed sensor (front right) plausibility during ABS regulation |
5DB0 | Wheel speed sensor (rear left) electrical failure |
5DB1 | Wheel speed sensor (rear left) plausibility at speed > 40km/h |
5DB2 | Wheel speed sensor pulse wheel (rear left) plausibility tooth fault every wheel revolution |
5DB3 | Wheel speed sensor (rear left) plausibility at speed < 20km/h |
5DB4 | Wheel speed sensor (rear left) plausibility during ABS regulation |
5DC0 | Wheel speed sensor (rear right) electrical failure |
5DC1 | Wheel speed sensor (rear right) plausibility at speed > 40km/h |
5DC2 | Wheel speed sensor pulse wheel (rear right) plausibility tooth fault every wheel revolution |
5DC3 | Wheel speed sensor (rear right) plausibility at speed < 20km/h |
5DC4 | Wheel speed sensor (rear right) plausibility during ABS regulation |
5DF0 | Pump unit |
5DF2 | Valve / ECU hardware failure |
5DF4 | Wiring supply voltage < 9 Volt |
5DF5 | Control unit internal failure |
5DF7 | Wiring supply voltage > 18 Volt |
5E00 | End of line test active |
5E01 | End of line test - Timeout |
5E02 | End of line test - Rotation rate sensor adjustment Error |
5E03 | End of line test - Rotation rate sensor Error |
5E04 | End of line test - Transverse acceleration sensor Error |
5E05 | End of line test - Transverse acceleration and rotation rate error |
5E06 | End of line test - Rotation rate sensor incorrectly mounted |
5E07 | End of line test - Transverse acceleration and rotation rate sensor incorrectly mounted |
5E08 | End of line test - Steering angle sensor error |
5E11 | Internal Error CAN controller |
5E14 | CAN Timeout DME/DDE |
5E15 | CAN Timeout EGS" |
5E16 | CAN Timeout instrument cluster |
5E18 | CAN DME/DDE data not plausible |
5E19 | CAN DME/DDE |
5E1A | CAN DME/DDE Signal Error |
5E1E | CAN Timeout LWS |
5E1F | LWS calibration VIN not initialized |
5E58 | ASC ECU receives LWS CAN data |
5E59 | Coding error |
5E5B | DSC push button pressed longer than 10 sec or Error |
5E5D | Brake fluid level switch error |
5E5E | Brake light switch error |
5E20 | Pressure Sensor 1 electrical failure |
5E21 | Pressure Sensor 2 electrical failure |
5E24 | Pressure Sensor 1/2 not plausible |
5E26 | Power supply sensors |
5E2F | Temperature Sensor |
5E30 | Transverse acceleration sensor electrical failure |
5E32 | Transverse acceleration sensor not plausible |
5E38 | Rotation rate sensor electrical failure |
5E3C | Rotation rate sensor not plausible |
5E40 | Steering angle sensor signal not plausible |
5E43 | Steering angle sensor internal |
5E4E | DSC Sensor Offset check |
5E4F | DSC continual valve operation |
0xXY | Unknown error location |
