Hello, I have an S54 that I flashed the CSL tune to. I am using an airbox with the Kassel MAP sensor, and an IAT sensor. My DME is an MSS54HP. I used the terra tune on the github, and I am still on the non-CSL bootloader (I am using the modified bootloader that allows a CSL map). My S54 is in my E36. I was able to do the swap coding and the car runs OK. (I have bogging but I think that is because I haven't touched the fuel tables and I have a somewhat stock S54 -- I did change the scaling for the stock non-CSL cams as per one of the write-ups).
My main concern is that there is no rev limiter. I have a friend with a similar tune and he claims to have the same issue on his S54 swapped E36.
Has anyone run in to this? Is there a way to fix this? If I change the rev limit using tunerpro, it doesn't seem to make any difference when I flash... The car will keep revving and not stop and so it is prone to over-revving.
I am using mostly tuner pro and MSSflasher.
Any help would be appreciated.
Thanks
Thanks
