Distinguished Coders and Tuners:
I am running into two separate, but very annoying issues, using NCS Expert and PASoft (aka BMW Scanner). Any thoughts, tips, tricks or insights would be greatly appreciated. Many thanks in advance.
PASoft Issue: When trying to code the IKE module, I receive the following error—“No coding data received”.
Reading and coding works (as far as I can tell) with all modules … except IKE. Of course, that’s the last one that needs coding. I’ve tried copying to/from the LCM module but can’t find clear instructions anywhere so I backed off to prevent damage.
NCS Expert: When trying to connect to the ECU in NCS, I receive the following error—“IFH-0009: No Response from Controlunit”.
INPA is working without issue. Black dots for battery and ignition. The Com port is configured with the proper baud and latency and the Ebiadas file is set up. Still, no luck getting into NCS with Revtor’s or any other profile, no matter which one of the four ecu options that I select.
