Clutch switch
  • nahvkolaj
    Are you using a black clutch switch, a brown clutch switch or a green clutch switch
    If it's a black clutch switch, what is the part number on it? Does it end in 700?
    If it's a green clutch switch, then you'll need to disable clutch switch in the ews module because the green clutch switch doesn't support ews interlock which is why you wouldn't be getting a signal
    If it's a brown clutch switch, I'm not sure then....
    It’s a supposedly “new” black clutch switch with P/N 61-31.9122700.9 etched on it.
    What is the correct behavior at Pin 4? Does the switch pull a 12V signal to ground from the EWS when the clutch is disengaged? Or does it send 12V to the EWS when the clutch is disengaged?
  • nextelbuddy
    Originally posted by nahvkolaj View Post
    Finally got back to this. Traced the wiring and all appears to be as it should be physically. I verified continuity of the harness as well. At the clutch switch connector:
    1. GND
    2. DME (12V clutch pedal up -> 0V clutch pressed)
    3. +12V
    4. EWS pin 8 (0V up -> 0V pressed)
    This thread was a big help: https://nam3forum.com/forums/forum/m...h-help-code-50
    Seems as if no meaningful signal is getting to the EWS. Bad switch warranting a call to Bimmerworld?
  • nahvkolaj
    1. GND
    3. +12V
  • ejendow
    I would also double check the harness you bought from AMS. The one I received from them had two pins mixed up that I didn't notice until my brake lights were always on while driving. This did not cause a no-start issue, but I'd still double check the wiring.
  • nahvkolaj
    Thanks for the advice. I’ll report back when I dig in and fix this after I get back from some work travel.
  • George Hill
    If you have a GPS and a 700 clutch switch everything in your car should be wired AND coded like a stock MT car, nothing custom.
    Pin #1 is ground
    Pin #3 is power
    Pin #4 of the clutch switch goes to pin #8 of the EWS. IF you do that then it will crank even if still coded as an SMG.
  • terra
    That would suggest the wiring between the clutch switch and EWS is incorrect. Even the non-M switch would work fine for EWS interlock purposes.
  • nahvkolaj
    I’m gonna resurrect this a bit to keep the clutch switch conversation going. Nearing the end of my manual conversion, and I can’t get the starter to engage. Here’s what I have:
    • Black “700” switch that Bimmerworld got from Germany. They called me on the phone and let me know they have difficulty sourcing the right switch due to P/N and manufacturing churn over last several years.
    • AMS wiring harness kit. Installed according to their instructions, everything seemed to go fine
    • Gear/neutral switch installed in transmission (the one with the pigtail)
    • DME flashed to stock manual binary with bytes at 0x4028, 0x67e0, and 0x35da set per the “SMG to 6MT Conversion” thread
    • Re-coded manual defaults to AKMB, ALSZ, EWS, DCT
    After all that, I tested what I could before trying cranking:
    • Reverse functions work: rear mirror dip, reverse lights, and PDC
    • I am seeing a discrete change (can’t remember the name of it) in INPA when I go from Neutral to any gear
    • Clutch switch appears to register digital signal in INPA.
    I did try coding the EWS to not require the clutch in (PARK/NEUTRAL_EINGANG=nicht_aktiv) and I got engine crank, but this of course removes clutch disengage required to start. I would prefer to have everything working as it should.
    I’m a bit stumped on where to go from here. It must be somewhere in the switch implementation. I might back probe the clutch switch to verify voltages are as expected, then beyond that all I can think is to pull apart the EWS and DME connectors to make sure I got everything in the right place. Pics attached of the switch and how the transmission sensors are hooked up.
  • M3fanatic580
    Originally posted by M3LSB.Gab View Post
    I replaced the clutch switch with the new black one that replaces the NLA brown one (PN 61319122700 - written 314 on it). The car idles better and no longer stall at stop, but it is not perfect. Maybe i'm too used to newer bmws now ^^. The one that was installed had 180804 written on it.
    What do you mean by "it is not perfect"? What issue are you still having?
  • ejendow
    I just changed the clutch switch. Not sure about the gear position sensor if it was installed with the manual swap or not. It is a zcp also.
    I would check to see if you have a GPS installed and if not, reference THIS thread to see if this line of code was changed.
  • M3LSB.Gab
    Originally posted by ejendow View Post
    did you install the gear position sensor on your car?
  • ejendow
    I replaced the clutch switch with the new black one that replaces the NLA brown one (PN 61319122700 - wrote 314 on it). The car idles better and no longer stall at stop, but it is not perfect. Maybe i'm too used to newer bmws now ^^. The one that was installed had 180804 written on it.
  • M3LSB.Gab
  • maupineda
    Back in 2022 I think. At the time the browns where already NLA and green was still available from FCP.
  • ejendow
    this was false internet information, I actually got TWO of the black flavor, and they did not work.
    Brown - good
    green - good if coded
    black - not good, the issue with this is the cruise control, it does not work.
    When did you buy these two switches?
