Hello All,
I am in the process of preparing my m3 for the track and have removed the two electric seats and to no surprise now have an airbag light in my cluster. I have done some research and found the below to be a solution by reusing the appropriate parts from the seats. This info was provided by Paraklas on e46fanactics:
1. Install the racing seats and use the OEM belt pre-tensioner unit. Connect the tensioner unit with the wiring loom under the seat.
2. Get an occupancy sensor bypass module ($15 /ebay) and connect it with the wiring on the passenger seat along with the tensioner.
I was thinking, why would I remove the weight of the seats, only to add some of it back in? To give you all a little more details on the direction of the build, I just installed a Kirk racing roll bar and have a Racetech RT4009 stealth on the way from New Zealand so that I can run a 6 point Schroth Flexi harness. As mentioned before, a solution is to install the original seat belt buckles which I don't need with the 6 point harness.
Does any one have any experience on how to code out the seat belt pretensions and the seat occupancy sensor using NCSExpert or some other tool?
Thanks,
Josh
Thanks,
Josh
