  • JP1580
    Yes, which?
    My reply got buried in the "quote thing"
    Was made of metal?Yes. Think of the stainless steel scrubbers for pots and pans. It was shoved in the inlet hole (small OD)
    Was it the regulator that supplies the vanos assembly or the regulator in the vanos valve block? Vanos assembly
    Picture is new replacement. I swapped my beisan o-rings.
  • ac427
    Originally posted by JP1580 View Post
    Yes, which?
  • JP1580
    Was made of metal? Yes. Think of the stainless steel scrubbers for pots and pans. It was shoved in the inlet hole (small OD)
  • ac427
    It was shoved in the inlet portion on the oil flow regulating valve.
    Was made of metal?
  • JP1580
  • ac427
    Update (with status)
    - VANOS test (using toolset32) -> FAIL (times out)
    - VANOS pressure test -> FAIL
    - Timing -> PASS
    - VANOS Oil Flow Regulating Valve - 11367830341 -> replaced. Found what appears to be a clog.
    - VANOS piston seals -> no nicks. Cleaned and reinstalled
    - VANOS high pressure pump -> cleaned and reinstalled
    - valve adjustment -> PASS
    - VANOS high pressure valve -> disassembled, cleaned and rebuilt. Seems to be functional.
    Planned:
    - Valve cover gasket
    - VANOS high pressure line
    - VANOS Accumulator
    If there are additional checks before I close the put the cover back on, let me know please.​
    Where did the stuff in the palm of your hand come from?
  • JP1580
    - Timing -> PASS
    Planned:
    - VANOS Accumulator
  • JP1580
    Heads up,
    I removed the nut, backed the screw out all the way to reveal the shaft with oring, spring and needle valve.
    Read that there's a captive washer inside that supposedly should rattle freely when you shake the valve body. Mine is now (maybe from some thick oil).
    Cleaned it out until things moved freely.
    Reassembled, and assembled back.
    I'll let the group know what's next progress wise.
  • Grime
    Learnt a lot from thread
  • JP1580
    I did just that and I could NOT move the the valve.
    I loosened the nut and moved the Allen head screw. I can feel the spring move in and out but I couldn't move it.
  • sapote
    remove the strain filter as in Pelican pics, and push down the valve nose to see if it move against the strong spring.
  • JP1580
    This is a refurbished valve block from Beisan.
    It included the high pressure regulator. Picture attached after I removed it to check if it was the root cause behind the low pressure
  • sapote
    Is that the piece that seats between the cylinder and the VANOS?
    If yes, I'm thinking of cleaning it with some brake cleaner fluid.
    I doubt this low P regulator is the cause as it lets the oil flow in the vanos and the gauge shows 50 - 60 psi. The high P regulator is the one I suggested, pic below with the red mark points to the spring loaded valve which when pushed down should push back by the strong spring (to keep it closed below the release pressure of around 1500 psi.
  • JP1580
    The low P: I vote for the broken spring P regulator, as nothing on the system can cause this total loss of P. Remove the regulator and check the filter for tear that allowed debris to jam open the valve, and check if the spring load small piston is still under high spring tension.
    So I have my acronym right:
    The low pressure regulator: not to be confused with the accumulator
    Or
    Should I buy a new one? PN confirmation (11367830341)
  • sapote
