Hey everyone, helping someone out with an E46 M3 that is having issues after having the vanos refurbished at another shop. The symptoms are the following DME codes:
1: Driver / fuel pump relay
5E: Inlet vanos, adaptation
B8: Function, inlet vanos
In addition to that there is also an issue where the car usually wont start on the first attempt. It will crank endlessly but usually fires right up the second try. It also feels very down on power compared to my E46 M3. I swapped in a tested good fuel pump relay which did not fix the starting issue. I am planning to measure fuel pressure to make sure the fuel pump is working fine, but I was wondering if the intake timing being off could possibly cause the hard starting issue and the vanos codes. I found this forum thread and the test Tomba made and ran it. (Thanks again Tomba, you tuned an E60 M5 bin for me a while back so I could run S65 injectors. Thank you Sapote as well for being so involved on the forum).
Here are the results:
Compared to the other results in this thread the intake values in test 1 and 2 seem very problematic. Since the minimum value is 38 and goes all the way up to the requested value of 75 do you all think that the intake cam being out of time could be the issue?Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
Start : 10.08.2026 18:51:47.0
Nr 1( 1) : 10.08.2026 18:51:47.4
apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
EVAN_ISTWERT = 38 00 26 .&
EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
EVAN_ISTWERT_EINH = Grad KW
EVAN_SOLLWERT_EINH = Grad KW
Nr 2( 1) : 10.08.2026 18:51:53.0
apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
EVAN_ISTWERT = 75 00 4B .K
EVAN_SOLLWERT = 75 00 4B .K
Nr 3( 1) : 10.08.2026 18:51:59.0
apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
EVAN_VERSTELLZEIT_FRUEH_EINH = ms
EVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 4( 1) : 10.08.2026 18:52:05.8
apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
Nr 5( 1) : 10.08.2026 18:52:20.7
apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 0 00 00 ..
AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
AVAN_ISTWERT_EINH = Grad KW
AVAN_SOLLWERT_EINH = Grad KW
Nr 6( 1) : 10.08.2026 18:52:26.2
apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 49 00 31 .1
AVAN_SOLLWERT = 55 00 37 .7
Nr 7( 1) : 10.08.2026 18:52:31.7
apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 165 00 A5 .¥
AVAN_VERSTELLZEIT_SPAET = 205 00 CD .Í
AVAN_VERSTELLZEIT_FRUEH_EINH = ms
AVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 8( 1) : 10.08.2026 18:52:38.4
apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
Stop : 10.08.2026 18:52:55.0
Dauer : 68.1 s
I appreciate the help!
Hello everyone, I found this post very interesting and I just tested it on an S50B32. Could someone tell me if my test is correct? Thank you.
Test file : C:\EDIABAS\ECU\BMW_S50B32_VANOS_TEST.TST
Start : 08.06.2025 10:44:35,0
Nr 1( 1) : 08.06.2025 10:44:35,1
apiJob("bmss501","ident","","")
ID_EML = 0 00 00 ..
ID_OBD2 = 0 00 00 ..
ID_AI_NR = 02
ID_HW_NR = 14 00 0E ..
ID_MOTOR = S50_MSS50
ID_SW_NR = 04
ID_BMW_NR = 1406611
ID_EWS_SS = 2 00 02 ..
ID_LIEF_NR = 0000115852
ID_PROD_NR = 971810576
JOB_STATUS = OKAY
ID_DATUM_KW = 20
ID_BUS_INDEX = 00
ID_COD_INDEX = 00
ID_DATUM_JAHR = 97
ID_DIAG_INDEX = 30
ID_LU_MESSUNG = 0 00 00 ..
ID_AIF_VORHANDEN = 1 00 01 ..
ID_LAMBDA_STEREO = 1 00 01 ..
ID_SG_HERSTELLER = 0 00 00 ..
Nr 2( 1) : 08.06.2025 10:44:35,2
apiJob("bmss501","STATUS_MOTORTEMPERATUR","","")
JOB_STATUS = OKAY
STATUS_MOTORTEMPERATUR_EINH = Grad C
STATUS_MOTORTEMPERATUR_WERT = 7.200000E+001
Nr 3( 1) : 08.06.2025 10:44:35,4
apiJob("bmss501","STATUS_OEL_TEMPERATUR","","")
JOB_STATUS = OKAY
STATUS_OEL_TEMPERATUR_EINH = Grad C
STATUS_OEL_TEMPERATUR_WERT = 4.300000E+001
Nr 4( 1) : 08.06.2025 10:44:35,7
apiJob("bmss501","STEUERN_EVANOS_FRUEHANSCHLAG","" ,"")
JOB_STATUS = OKAY
EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
EVAN_SOLLWERT = 0 00 00 ..
Nr 5( 1) : 08.06.2025 10:44:41,0
apiJob("bmss501","STEUERN_EVANOS_SPAETANSCHLAG","" ,"")
JOB_STATUS = OKAY
EVAN_ISTWERT = 59 00 3B .;
EVAN_SOLLWERT = 60 00 3C .<
Nr 6( 1) : 08.06.2025 10:44:46,3
apiJob("bmss501","STEUERN_EVANOS_VERSTELLZEIT","", "")
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 142 00 8E .?
EVAN_VERSTELLZEIT_SPAET = 174 00 AE .®
Nr 7( 1) : 08.06.2025 10:44:52,6
apiJob("bmss501","STEUERN_EVANOS_DICHTHEIT","","")
JOB_STATUS = OKAY
EVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
Nr 8( 1) : 08.06.2025 10:45:06,9
apiJob("bmss501","STEUERN_AVANOS_FRUEHANSCHLAG","" ,"")
JOB_STATUS = OKAY
AVAN_ISTWERT = 1 00 01 ..
AVAN_SOLLWERT = 0 00 00 ..
Nr 9( 1) : 08.06.2025 10:45:12,3
apiJob("bmss501","STEUERN_AVANOS_SPAETANSCHLAG","" ,"")
JOB_STATUS = OKAY
AVAN_ISTWERT = 40 00 28 .(
AVAN_SOLLWERT = 45 00 2D .-
Nr10( 1) : 08.06.2025 10:45:17,6
apiJob("bmss501","STEUERN_AVANOS_VERSTELLZEIT","", "")
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 184 00 B8 .¸
AVAN_VERSTELLZEIT_SPAET = 225 00 E1 .á
Nr11( 1) : 08.06.2025 10:45:23,8
apiJob("bmss501","STEUERN_AVANOS_DICHTHEIT","","")
JOB_STATUS = OKAY
AVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
Stop : 08.06.2025 10:45:38,4
Dauer : 63,4 s
Actually you don't need to retime engine- there is full diapason of vanos (from -2 to 58 (60 degrees) and from -1 to 47 (48 degrees). Starting position of cams will be zeroed with adaptations.Originally posted by Deutsch View PostTomba, thank you so much for the .tst file! Very easy to perform with tools that I already own!
To keep the thread rolling, here are my results from the test, on a freshly rebuilt motor with all new chains, chain guides, vanos seals, etc. with a few dyno pulls and 1 race weekend on it.
I may re-time it over the winter to get that last 2 degrees on the intake cam.
Start : 29.10.2024 17:28:44.6
Nr 1( 1) : 29.10.2024 17:28:44.8
JOB_STATUS = OKAY
EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
Nr 2( 1) : 29.10.2024 17:28:50.2
JOB_STATUS = OKAY
EVAN_ISTWERT = 58 00 3A .:
Nr 3( 1) : 29.10.2024 17:28:55.7
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 263 01 07 ..
EVAN_VERSTELLZEIT_SPAET = 226 00 E2 .â
Nr 4( 1) : 29.10.2024 17:29:02.1
JOB_STATUS = OKAY
Nr 5( 1) : 29.10.2024 17:29:16.5
JOB_STATUS = OKAY
AVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
Nr 6( 1) : 29.10.2024 17:29:22.0
JOB_STATUS = OKAY
AVAN_ISTWERT = 47 00 2F ./
Nr 7( 1) : 29.10.2024 17:29:27.4
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 219 00 DB .Û
AVAN_VERSTELLZEIT_SPAET = 215 00 D7 .×
Nr 8( 1) : 29.10.2024 17:29:33.8
JOB_STATUS = OKAY
Stop : 29.10.2024 17:29:48.8
Dauer : 64.2 s
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
JOB_STATUS = OKAY
Dauer : 64.2 s
This sounds like the CSL tune on stock cams if your marbles are below 2800rpm or so at medium/high throttle. Cam offsets will not solve this. I believe the only way to eliminate it is to remap several of the fields in the CSL file itself beyond a simple tune. As Heinz mentioned, I have created maps that solve this and bring back stock drivability. I call them the mullet tune. If you’re interested, shoot me a PM.Originally posted by nextelbuddy View PostSo I had a question about the Vanos test.
One of my cars is starting to have the marbles in a can sound at low RPM with a load on the engine. Sounds like pinging but it's a fresh rebuild. It's the same sign you're hearing cars when you run low octane fuel when you get the marbles in the canned sound.
Doing some searching I came across several instances where they mentioned timing being off.
I have never heard the pinging before until recently, so my guess is maybe it would probably go away if I reset Vanos adaptations and then probably come back
So if I want to run the Vanos test, should I run it now and it's current state or should I run it after I reset adaptations?
And would a successful vanos test mean that the engine is properly timed
I also had these Shadow codes. I never saw a check engine light but I decided to check codes today and saw these Shadow codes. Inlet Vanos retard valve errors
It's very simple, not rocket science.Originally posted by nextelbuddy View PostThanks sir for looking. I really need to learn how to decipher these values my self
The first job performed is STEUERN_EVANOS1_FRUEHANSCHLAG -> Command inlet VANOS advance until endstop.
When it completes you get back the SOLLWERT, German for setpoint, and the ISTWERT, which is the actual value.
The setpoint gets always set to -10, the value it expects to see is 0.
I would say +-1 would be deemed good, +-2 would be acceptable, anything beyond that and your engine just isn't in time properly.
After that it goes to STEUERN_EVANOS1_SPAETANSCHLAG -> Command inlet VANOS retard until endstop.
The setpoint here is 75, while it expects to see 60. Again here +-1 would be good +-2 would be acceptable, etc.
Next up is STEUERN_EVANOS1_VERSTELLZEIT -> Command inlet VANOS adjustment time
It returns EVAN_VERSTELLZEIT_FRUEH which is the time it took to fully retard the intake cam, and EVAN_VERSTELLZEIT_SPAET which represents the time it took to fully advance the intake cam.
We consider under 250ms-ish good here, DIS allows up to 500ms before it fails you.
The rest of the test is the same thing but for the AVANOS which is just the exhaust side.
The only difference being the intake ranges from 0-60, while the exhaust ranges from 0-48, same tolerances apply, exhaust is usally a bit faster on the adjustment due to less range.
+1Originally posted by Tomba View Postpinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
Grab yourself a Bryson mullet tune
Possibly, I and to some octane booster and see if there's any changeOriginally posted by elbert View PostMaybe some bad fuel?
Thanks sir for looking. I really need to learn how to decipher these values my selfOriginally posted by Tomba View PostLooks good, intake is 1 degree off but I wouldn't change it. So far nothing strange I could observe with these values.
I want to go can a few pages and compare the test results from my s54 turbo car and thus S54 wagon and see how they compare.
This is what my adaptations currently are using ecuworxOriginally posted by Tomba View Postpinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
This is my first and 2nd vanos test run back to back oil temp was normal and i just came back from daycare drop off driving for 45 min with some spirited driving in between after dropping kids off of course.
Code:Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST Start : 23.10.2024 09:05:37.3 Nr 1( 1) : 23.10.2024 09:05:37.4 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 23.10.2024 09:05:42.8 apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 59 00 3B .; EVAN_SOLLWERT = 75 00 4B .K EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 23.10.2024 09:05:48.2 apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY EVAN_VERSTELLZEIT_FRUEH = 319 01 3F .? EVAN_VERSTELLZEIT_SPAET = 261 01 05 .. EVAN_VERSTELLZEIT_FRUEH_EINH = ms EVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 4( 1) : 23.10.2024 09:05:54.5 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet Nr 5( 1) : 23.10.2024 09:06:08.9 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 0 00 00 .. AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 6( 1) : 23.10.2024 09:06:14.3 apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 48 00 30 .0 AVAN_SOLLWERT = 55 00 37 .7 AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 7( 1) : 23.10.2024 09:06:19.6 apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY AVAN_VERSTELLZEIT_FRUEH = 226 00 E2 .â AVAN_VERSTELLZEIT_SPAET = 211 00 D3 .Ó AVAN_VERSTELLZEIT_FRUEH_EINH = ms AVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 8( 1) : 23.10.2024 09:06:25.9 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet Stop : 23.10.2024 09:06:41.0 Dauer : 63.7 s
Code:Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST Start : 23.10.2024 09:09:47.8 Nr 1( 1) : 23.10.2024 09:09:47.9 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 23.10.2024 09:09:53.3 apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 59 00 3B .; EVAN_SOLLWERT = 75 00 4B .K EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 23.10.2024 09:09:58.6 apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY EVAN_VERSTELLZEIT_FRUEH = 321 01 41 .A EVAN_VERSTELLZEIT_SPAET = 258 01 02 .. EVAN_VERSTELLZEIT_FRUEH_EINH = ms EVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 4( 1) : 23.10.2024 09:10:05.0 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet Nr 5( 1) : 23.10.2024 09:10:19.5 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 0 00 00 .. AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 6( 1) : 23.10.2024 09:10:24.8 apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 49 00 31 .1 AVAN_SOLLWERT = 55 00 37 .7 AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 7( 1) : 23.10.2024 09:10:30.3 apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY AVAN_VERSTELLZEIT_FRUEH = 251 00 FB .û AVAN_VERSTELLZEIT_SPAET = 211 00 D3 .Ó AVAN_VERSTELLZEIT_FRUEH_EINH = ms AVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 8( 1) : 23.10.2024 09:10:36.6 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet Stop : 23.10.2024 09:10:51.7 Dauer : 63.9 s Last edited by nextelbuddy; 10-23-2024, 05:15 AM.
