  • Tomba
    pinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
  • nextelbuddy
    Originally posted by Tomba View Post
    Doesn't matter
    Was the engine rebuild with different than OEM components?
    The engine was built with all BMW parts from FCP Euro. The reason I question anything is because I used a non-bmw timing, bridge and pins when I did the timing.
    The engine has been running great with no other issues other than this weird pinging sound that just started coming out of nowhere
    I'm on the CSL tune with the non CSL Vanos offsets that I found on these forums.
    If the Vanos test comes back clean then I'm going to try using a stock CSL too without modified Vanos offsets and see if that changes anything.
  • Tomba
    So if I want to run the Vanos test, should I run it now and it's current state or should I run it after I reset adaptations?
    Doesn't matter
    And would a successful vanos test mean that the engine is properly timed
  • nextelbuddy
    So I had a question about the Vanos test.
    One of my cars is starting to have the marbles in a can sound at low RPM with a load on the engine. Sounds like pinging but it's a fresh rebuild. It's the same sign you're hearing cars when you run low octane fuel when you get the marbles in the canned sound.
    Doing some searching I came across several instances where they mentioned timing being off.
    I have never heard the pinging before until recently, so my guess is maybe it would probably go away if I reset Vanos adaptations and then probably come back
    I also had these Shadow codes. I never saw a check engine light but I decided to check codes today and saw these Shadow codes. Inlet Vanos retard valve errors
  • BMWfanz
    Guys, anyone have 288/280 12.5 lift cams and who has done vanos test?
  • Tomba
    Originally posted by kaiv View Post
    Very cool!
    Any chance you could whip up something for VANOS adaptions reset in INPA? It's a bit a chore to have to fire up DIS for every Vanos rebuild.
    I'm busy integrating VANOS test in INPA and some more functionalities. Sure to add that one as well.
  • Slideways
    Doesn't resetting all engine adaptations on INPA include the VANOS?
  • heinzboehmer
    Very cool!
    This tool is even faster than INPA
    As per the title I've just put together a new utility for you guys that can do a few basics on the DME. Click image for larger version Name: DME_Utility-Release.png Views: 0 Size: 30.8 KB ID: 20329 Click image for larger version Name: DME_Utility-Release-Codes.png Views: 0 Size: 17.7 KB ID: 20330 The software can be used
  • kaiv
    Unzip the attachment,
    place it in C:\EDIABAS\ECU
    start Tool32
    Click the 2nd [OPEN] icon
    open MSS54_VANOS_Test.tst
    Press F8 to run all tests
    A result screen similar to the quoted code text below should appear *tested only with bench set up! Not with a running engine
    Code:
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
    Start : 18.06.2020 19:57:00.5
    Nr 1( 1) : 18.06.2020 19:57:00.6
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 60 00 3C .<
    EVAN_SOLLWERT = 52 00 34 .4
    EVAN_ISTWERT_EINH = Grad KW
    EVAN_SOLLWERT_EINH = Grad KW
    Nr 2( 1) : 18.06.2020 19:57:06.0
    apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 3( 1) : 18.06.2020 19:57:11.3
    apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    EVAN_VERSTELLZEIT_FRUEH_EINH = ms
    EVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 4( 1) : 18.06.2020 19:57:17.5
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
    Nr 5( 1) : 18.06.2020 19:57:32.0
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 0 00 00 ..
    AVAN_SOLLWERT = 0 00 00 ..
    AVAN_ISTWERT_EINH = Grad KW
    AVAN_SOLLWERT_EINH = Grad KW
    Nr 6( 1) : 18.06.2020 19:57:37.3
    apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 7( 1) : 18.06.2020 19:57:42.5
    apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    AVAN_VERSTELLZEIT_FRUEH_EINH = ms
    AVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 8( 1) : 18.06.2020 19:57:48.9
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
    Stop : 18.06.2020 19:58:03.3
    Dauer : 62.9 s
    Very cool!
  • Tomba
    Originally posted by jpy1980 View Post
    I had a p0011 and p0014.
    These are camshaft position sensors. Once these don't work, the VANOS test won't work.
  • jpy1980
    Your desired values our out of specification which is very weird!
    Any error codes?
    Hello!
    I had a p0011 and p0014. Then I changed my solenoid pack, cleaned the valve body and changed the o rings. After that I was getting a p0012 code but my p0011 and p0014 disappeared. Also my car would not stay on as it would die when coming to a stop.
    ended up getting the car towed to a shop. We will see what they say.
  • Tomba
    Any error codes?
  • oceansize
    Can't interpret from this, your output is missing required information (solenoid coil pack has likely failed).
  • jpy1980
    Hey guys im having issues with my car and I was told to run this test. Any feedback is appreciated. Thanks!
    Start : 29.04.2024 19:15:36.2
    Nr 1( 1) : 29.04.2024 19:15:36.3
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 59 00 3B .;
    Nr 2( 1) : 29.04.2024 19:15:41.7
    JOB_STATUS = OKAY
    Nr 3( 1) : 29.04.2024 19:15:47.0
    JOB_STATUS = OKAY
    Nr 4( 1) : 29.04.2024 19:15:53.3
    JOB_STATUS = OKAY
    Nr 5( 1) : 29.04.2024 19:16:07.7
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 48 00 30 .0
    AVAN_SOLLWERT = 20 00 14 ..
    Nr 6( 1) : 29.04.2024 19:16:13.0
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 49 00 31 .1
    Nr 7( 1) : 29.04.2024 19:16:18.3
    JOB_STATUS = OKAY
    Nr 8( 1) : 29.04.2024 19:16:24.6
    JOB_STATUS = OKAY
    Stop : 29.04.2024 19:16:39.7
    Dauer : 63.5 s
  • BMWfanz
    Originally posted by inlinesix123 View Post
    Hi everyone, big thanks to Tomba for putting this test together.
    Is there anyone here who can check my results? Im chasing some vague vanos codes when running the car hard.
    JOB_STATUS = OKAY
    EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
    EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    Nr 2( 1) : 19.01.2024 19:56:51.5
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 57 00 39 .9
    EVAN_SOLLWERT = 75 00 4B .K
    Nr 3( 1) : 19.01.2024 19:56:56.9
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 229 00 E5 .å
    EVAN_VERSTELLZEIT_SPAET = 212 00 D4 .Ô
    Nr 4( 1) : 19.01.2024 19:57:03.4
    JOB_STATUS = OKAY
    Nr 5( 1) : 19.01.2024 19:57:17.8
    JOB_STATUS = OKAY
    AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    Nr 6( 1) : 19.01.2024 19:57:23.1
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 47 00 2F ./
    AVAN_SOLLWERT = 55 00 37 .7
    Nr 7( 1) : 19.01.2024 19:57:28.4
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 193 00 C1 .Á
    AVAN_VERSTELLZEIT_SPAET = 190 00 BE .¾
    Nr 8( 1) : 19.01.2024 19:57:34.8
    JOB_STATUS = OKAY
    Stop : 19.01.2024 19:57:49.7
    Dauer : 63.8 s
    Hi! Intake camshaft is out of spec on 2 degrees but here shouldnt be any issues, but it not work in full 60 degrees, 59 only, same with exhaust- position is good but 47 degrees, should be 48. Reaction time is good!
