Hi everyone, big thanks to Tomba for putting this test together.
Is there anyone here who can check my results? Im chasing some vague vanos codes when running the car hard.
apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
EVAN_ISTWERT_EINH = Grad KW
EVAN_SOLLWERT_EINH = Grad KW
Nr 2( 1) : 19.01.2024 19:56:51.5
apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
EVAN_ISTWERT = 57 00 39 .9
EVAN_SOLLWERT = 75 00 4B .K
Nr 3( 1) : 19.01.2024 19:56:56.9
apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 229 00 E5 .å
EVAN_VERSTELLZEIT_SPAET = 212 00 D4 .Ô
EVAN_VERSTELLZEIT_FRUEH_EINH = ms
EVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 4( 1) : 19.01.2024 19:57:03.4
apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
Nr 5( 1) : 19.01.2024 19:57:17.8
apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 0 00 00 ..
AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
AVAN_ISTWERT_EINH = Grad KW
AVAN_SOLLWERT_EINH = Grad KW
Nr 6( 1) : 19.01.2024 19:57:23.1
apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 47 00 2F ./
AVAN_SOLLWERT = 55 00 37 .7
Nr 7( 1) : 19.01.2024 19:57:28.4
apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 193 00 C1 .Á
AVAN_VERSTELLZEIT_SPAET = 190 00 BE .¾
AVAN_VERSTELLZEIT_FRUEH_EINH = ms
AVAN_VERSTELLZEIT_SPAET_EINH = ms
Nr 8( 1) : 19.01.2024 19:57:34.8
apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
JOB_STATUS = OKAY
AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
Stop : 19.01.2024 19:57:49.7
Dauer : 63.8 s
I ran those two tests, FRUEHANSCHLAG (early stop?) then DICHTHEIT (leak test) on a warm engine.
Intake and exhaust both gave status "Messung beendet, Soll-/Istwert-Vergleich ausfuehren" ("Measurement finished, carry out setpoint/actual value comparison") and setpoint and actual are within 5 degrees, so it seems leak/drift is okay!
Here are my results:
It's pretty straight forward, but in case anyone needs it I added a test file, just like with the other one, unzip it and place it in C:\EDIABAS\EcuCode:Test file : C:\EDIABAS\ECU\MSS54_VANOS_LEAKTESTS.TST Start : 06.10.2023 11:55:06.8 Nr 1( 1) : 06.10.2023 11:55:06.9 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 0 00 00 .. EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 06.10.2023 11:55:12.4 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY EVAN_STATUS = Messung beendet, Soll-/Istwert-Vergleich ausfuehren EVAN_ISTWERT = 48 00 30 .0 EVAN_SOLLWERT = 45 00 2D .- EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 06.10.2023 11:55:27.0 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 0 00 00 .. AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 4( 1) : 06.10.2023 11:55:32.3 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY AVAN_STATUS = Messung beendet, Soll-/Istwert-Vergleich ausfuehren AVAN_ISTWERT = 17 00 11 .. AVAN_SOLLWERT = 15 00 0F .. AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Stop : 06.10.2023 11:55:47.9 Dauer : 41.1 s
The contents are exactly what Tomba recommended, but for both intake and exhaust.
Thanks again Tomba!Code:1|mss54ds0|STEUERN_EVANOS1_FRUEHANSCHLAG 1|mss54ds0|STEUERN_EVANOS1_DICHTHEIT 1|mss54ds0|STEUERN_AVANOS1_FRUEHANSCHLAG 1|mss54ds0|STEUERN_AVANOS1_DICHTHEIT
The dichtheid test, I already posted my suspicion on this. Maybe it needs to be set differently. I do had a few cars in the past who succeeded the test flawlessly. Newer ECUs have the ability to show the actual measured values during such tests. For the MSS54 I haven't found it yet.
Before the test the VANOS piston might need to move up (advance) then close both control valves (advance & retard) and observe the drift. A leak free system shouldn't drift to much. But I do suspect it is set correctly once the test it self is started.
You can try the following,
1. STEUERN_EVANOS1_FRUEHANSCHLAG and then,
2. STEUERN_EVANOS1_DICHTHEIT
Other option would be to activate the solenoids on your own with a separate device to advance with the engine speed lifted [STEUERN_LLS_TESTDREHZAHL] and then observe how the actual camshaft is moving once you don't activate them [STATUS_EVANOS1_IST] for intake, I would suggest TestO with DS2 Serial job for exhaust as I can't find the actual exhaust vanos position it in the job list.
Numbers do look good in your result.
Thanks Tomba for putting together the test file, it's super helpful. I couldn't get the VANOS tests in INPA since I have a K+DCAN cable and DIS didn't show VANOS tests, so your test file was perfect for me!
I recently did a full VANOS rebuild using Beisan components (solenoid pack, all seals, pump disk, pressure regulator filter, cleaned vanos valve/manifold, etc) and ran the tests with a fully warmed up engine with 100 miles on it since the rebuild.
Code:Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST Start : 04.10.2023 13:26:00.3 Nr 1( 1) : 04.10.2023 13:26:00.4 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","") JOB_STATUS = OKAY [EVAN_ISTWERT = 0 00 00 .. EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 04.10.2023 13:26:06.0 apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","") JOB_STATUS = OKAY EVAN_ISTWERT = 59 00 3B .; EVAN_SOLLWERT = 75 00 4B .K EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 04.10.2023 13:26:11.3 apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","") JOB_STATUS = OKAY EVAN_VERSTELLZEIT_FRUEH = 209 00 D1 .Ñ EVAN_VERSTELLZEIT_SPAET = 221 00 DD .Ý EVAN_VERSTELLZEIT_FRUEH_EINH = ms EVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 4( 1) : 04.10.2023 13:26:17.9 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ") JOB_STATUS = OKAY EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet Nr 5( 1) : 04.10.2023 13:26:32.6 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","") JOB_STATUS = OKAY AVAN_ISTWERT = 0 00 00 .. AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 6( 1) : 04.10.2023 13:26:38.1 apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","") JOB_STATUS = OKAY AVAN_ISTWERT = 48 00 30 .0 AVAN_SOLLWERT = 55 00 37 .7 AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 7( 1) : 04.10.2023 13:26:43.5 apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","") JOB_STATUS = OKAY AVAN_VERSTELLZEIT_FRUEH = 167 00 A7 .§ AVAN_VERSTELLZEIT_SPAET = 190 00 BE .¾ AVAN_VERSTELLZEIT_FRUEH_EINH = ms AVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 8( 1) : 04.10.2023 13:26:50.1 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ") JOB_STATUS = OKAY AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet Stop : 04.10.2023 13:27:05.1 Dauer : 64.9 s
It looks like angles and reaction time look good. I did rerun it and the intake showed 60 instead of 59; either way, it doesn't seem concerning. I actually had a hard time with timing the intake. It kept being off a little bit, but sapote had some great advice and discussion on another thread on how to get it shored up. So also, thank you sapote!
The only thing I don't understand is the leak test (DICHTHEIT/dichtheitsprüfung) results. It says that both intake and exhaust both drifted prematurely (Einheit vorzeitig weggedriftet). Is this actually a problem or does it always say this? Looking at all the other post they all seem to say this.Last edited by Adam_; 10-04-2023, 05:27 PM.
Yeah, always different values in each test, already installed beisan kit on mechanical vanos part, didnt maintaned solenoids. Now i'm in doubts- buy new coil pack or whole vanos module, but ECU didnt show any error codes on vanos or camhaft position at allOriginally posted by Tomba View Post
Your exhaust camshaft does not reach the end stops (0 - 45). It also doesn't use the full range (+45 degrees). Doubt it would be a timing issue. More solenoids and or piston seals.Last edited by BMWfanz; 09-18-2023, 03:03 AM.
Your exhaust camshaft does not reach the end stops (0 - 45). It also doesn't use the full range (+45 degrees). Doubt it would be a timing issue. More solenoids and or piston seals.Originally posted by BMWfanz View PostapiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
JOB_STATUS = OKAY
AVAN_ISTWERT = 36 00 24 .$
AVAN_SOLLWERT = -10 FF FF FF F6 yyyo
Nr 6( 1) : 16.09.2023 16:01:23,2
JOB_STATUS = OKAY
AVAN_ISTWERT = 39 00 27 .'
Done several tests- Intake cam is stable from -1 to 59, exhaust has different angles- first as i see- adaptation on exhaust cam is -8, so in tests i've seen different results- first test on exhaust where target is -10 fact angles was: -3, -5, -8, +10 +15 +13 etc, cam is always has different start position, when second test in advance- +40, +38, +37 etc. Engine has 288/280 shrick cams and no error codes at all, is it could be solenoids pack issue or mecanical wrong timed exhaust cam? will do retiming soon, but now i aware of vanos- should i change it or it is only timing issue
Guys, done vanos rebuild and test in tool32. Are all ok? I Think something wrong with exhaust cam. Someone who understands results- comment plz
Start : 16.09.2023 16:00:46,5
Nr 1( 1) : 16.09.2023 16:00:46,6
JOB_STATUS = OKAY
EVAN_ISTWERT = -1 FF FF FF FF yyyy
EVAN_SOLLWERT = -10 FF FF FF F6 yyyo
Nr 2( 1) : 16.09.2023 16:00:51,9
JOB_STATUS = OKAY
Nr 3( 1) : 16.09.2023 16:00:57,2
JOB_STATUS = OKAY
EVAN_VERSTELLZEIT_FRUEH = 228 00 E4 .a
EVAN_VERSTELLZEIT_SPAET = 219 00 DB .U
Nr 4( 1) : 16.09.2023 16:01:03,5
JOB_STATUS = OKAY
Nr 5( 1) : 16.09.2023 16:01:17,8
JOB_STATUS = OKAY
JOB_STATUS = OKAY
Nr 7( 1) : 16.09.2023 16:01:28,5
JOB_STATUS = OKAY
AVAN_VERSTELLZEIT_FRUEH = 165 00 A5 .?
AVAN_VERSTELLZEIT_SPAET = 205 00 CD .I
Nr 8( 1) : 16.09.2023 16:01:34,8
JOB_STATUS = OKAY
Stop : 16.09.2023 16:01:49,4
Dauer : 62,9 sLast edited by BMWfanz; 09-16-2023, 04:10 AM.
Looks fine. Reaction time is really good.
intake &exhaust camshafts is 1 degree out of spec. But I wouldn't bother. 1 degree is fine.
So finally got time to run this test. Took the car for a spirited drive before testing.
Here are my results. I think it looks okay compared to other peoples results?
Code:Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST Start : 02.09.2023 14:34:57.4 Nr 1( 1) : 02.09.2023 14:34:57.6 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 02.09.2023 14:35:03.0 apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 59 00 3B .; EVAN_SOLLWERT = 75 00 4B .K EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 02.09.2023 14:35:08.4 apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY EVAN_VERSTELLZEIT_FRUEH = 205 00 CD .Í EVAN_VERSTELLZEIT_SPAET = 206 00 CE .Î EVAN_VERSTELLZEIT_FRUEH_EINH = ms EVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 4( 1) : 02.09.2023 14:35:14.7 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet Nr 5( 1) : 02.09.2023 14:35:29.2 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 1 00 01 .. AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 6( 1) : 02.09.2023 14:35:34.5 apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 48 00 30 .0 AVAN_SOLLWERT = 55 00 37 .7 AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 7( 1) : 02.09.2023 14:35:39.8 apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY AVAN_VERSTELLZEIT_FRUEH = 168 00 A8 .¨ AVAN_VERSTELLZEIT_SPAET = 213 00 D5 .Õ AVAN_VERSTELLZEIT_FRUEH_EINH = ms AVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 8( 1) : 02.09.2023 14:35:46.3 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet Stop : 02.09.2023 14:36:01.6 Dauer : 64.2 s
Yeah, same cable and idle, as i remember- coolant and oil temp above ~60Originally posted by elrichmeister View PostSorry if this is a super noob question.
All i need is the same cable I use for INPA to conduct this test?
The car needs to be idling to run the test?
The first thing in your log it commands the intake to -10, the result it wants to see is 0, the result you get is 15, so the cam isn’t able to retard all the way it wants to, the computer obviously knows this so no wonder it sets a code.Originally posted by nextelbuddy View PostA friend of mine has an S54 in an E30 he did a Vanos refresh with beisan parts but now has a code for inlet Vanos.
We ran a Vanos test using the script in this thread and not really sure how to interpret it but it doesn't look good. We ran the test two times and the results look similar, can we drove the car for about 30 minutes? Getting everything nice and hot still the results look pretty similar.
I'm starting to think that they didn't set the timing right the plungers and the range of the cam gear sprockets..
Exhaust side looks fine. It's the intake side that looks like it has a mechanical issue.
The second thing wrong with your log is the adjustment times for the intake being just 0, I think this is just a result of the same issue since it doesn’t make sense measuring the adjustment time for an adjustment that doesn’t have the entire proper range available to it.
So yeah, disassemble and figure out what went wrong.
Code:Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST Start : 11.08.2023 16:56:41.4 Nr 1( 1) : 11.08.2023 16:56:41.4 apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 15 00 0F .. EVAN_SOLLWERT = -10 FF FF FF F6 ���� EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 2( 1) : 11.08.2023 16:56:46.8 apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY EVAN_ISTWERT = 59 00 3B .; EVAN_SOLLWERT = 75 00 4B .K EVAN_ISTWERT_EINH = Grad KW EVAN_SOLLWERT_EINH = Grad KW Nr 3( 1) : 11.08.2023 16:56:52.0 apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY EVAN_VERSTELLZEIT_FRUEH = 0 00 00 .. EVAN_VERSTELLZEIT_SPAET = 0 00 00 .. EVAN_VERSTELLZEIT_FRUEH_EINH = ms EVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 4( 1) : 11.08.2023 16:56:58.3 apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet Nr 5( 1) : 11.08.2023 16:57:12.7 apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 0 00 00 .. AVAN_SOLLWERT = -10 FF FF FF F6 ���� AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 6( 1) : 11.08.2023 16:57:18.0 apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG","","") JOB_STATUS = OKAY AVAN_ISTWERT = 48 00 30 .0 AVAN_SOLLWERT = 55 00 37 .7 AVAN_ISTWERT_EINH = Grad KW AVAN_SOLLWERT_EINH = Grad KW Nr 7( 1) : 11.08.2023 16:57:23.2 apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT","","") JOB_STATUS = OKAY AVAN_VERSTELLZEIT_FRUEH = 179 00 B3 .� AVAN_VERSTELLZEIT_SPAET = 171 00 AB .� AVAN_VERSTELLZEIT_FRUEH_EINH = ms AVAN_VERSTELLZEIT_SPAET_EINH = ms Nr 8( 1) : 11.08.2023 16:57:29.5 apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","") JOB_STATUS = OKAY AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet Stop : 11.08.2023 16:57:44.2 Dauer : 62.9 s
