  • sapote
    Originally posted by JBAshland View Post
    error codes:
    10: Signal: Camshaft sensor, Exhaust
    15: Camshaft sensor 1: Synchronization to Crankshaft
    185: Function: Exhaust VANOS
    72 EVANOS1-late valve
    code 72 (48 hex) makes no sense as the vanos test report shows Intake cam max retard of 57 within 1 degree of the desired 60*, so why code 72 says it's too retarded?
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
    EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
    EVAN_ISTWERT = 57 00 39 .9
    EVAN_SOLLWERT = 75 00 4B .K​
  • sapote
    Originally posted by Tomba View Post
    Good question,
    I don't know the routines for the DME to trigger the error codes.
    I would expect the DME to check a level / edge from trigger wheel between low and high or visa versa during a certain crank angle window to detect a working sensor.
    Maybe the window is small and it can trigger both codes? Even in newer ECU I see these 2 codes sometimes together.
    May be the error is too large, above certain threshold -- the IN cam was 38* retarded instead of 0 -- and this caused the DME to issue codes 10 and 15 combo.
  • Tomba
    Tomba, If the EX cam was too advance, why the DME didn't just issue the timing error code instead of error 10 and 15 combo? There are distint codes for VANOS too retarded or too advance, but I rarely see the combo of 10 and 15. Also the poster confirmed that after re-timed the cam then the error 10 and 15 gone.
    Good question,
  • sapote
    Originally posted by alpinem3e46 View Post
    I think my next step will be to order the timing tools and see if it’s in time.
    no need to buy the tool for checking the timing. Do this: VC rempved, turn crank CW to TDC compression, #1 cam lobes should be pointing at each other at about 45* with the cam holes pointing close to vertical ref to the head top flat surface. remove the vanos IN piston front cover and the vanos piston should be about 1mm below the cover interface surface. in your case I believe the piston protrudes out quite a bit. To correct the problem, keep crank at TDC and with the vanos piston protrudes out, install the cover to push the piston back in at the max retard, loosen the hub bolts and proceed to set the timing such as the IN cam hole is 90* to the head top surface. run the Tool32 again to verify.
    Note: the perfect timing set the hole not perfectly 90* to the head surface, but using 90* vertical is close enough for the job without the bridge tool.
  • alpinem3e46
    It expects to see 0 and yours is 38, meaning the intake cam is too retarded. Need to remove valve cover and double check the vanos timing on the Intake side.
    How did you check the cam timing? Using the bridge tool?
    I haven’t checked cam timing yet, the results from that vanos test are what made me think the intake cam timing is likely off. Unfortunately I am not sure what the previous shop that rebuilt the vanos did. The owner of this M3 tells me that it has had that code since the vanos work. I think my next step will be to order the timing tools and see if it’s in time.
    Thanks again! I really appreciate your input.
  • sapote
    15: Camshaft sensor 1: Synchronization to Crankshaft.......
    This means that the expected crank angle window/range when a rising/falling edge is expected isn't happening. In your case it might be caused by the missing signal from the error code above.​
  • sapote
    Compared to the other results in this thread the intake values in test 1 and 2 seem very problematic. Since the minimum value is 38 and goes all the way up to the requested value of 75 do you all think that the intake cam being out of time could be the issue?
    I appreciate the help!
  • sapote
    I will take a look
  • alpinem3e46
    Hey everyone, helping someone out with an E46 M3 that is having issues after having the vanos refurbished at another shop. The symptoms are the following DME codes:
    1: Driver / fuel pump relay
    5E: Inlet vanos, adaptation
    B8: Function, inlet vanos
    In addition to that there is also an issue where the car usually wont start on the first attempt. It will crank endlessly but usually fires right up the second try. It also feels very down on power compared to my E46 M3. I swapped in a tested good fuel pump relay which did not fix the starting issue. I am planning to measure fuel pressure to make sure the fuel pump is working fine, but I was wondering if the intake timing being off could possibly cause the hard starting issue and the vanos codes. I found this forum thread and the test Tomba made and ran it. (Thanks again Tomba, you tuned an E60 M5 bin for me a while back so I could run S65 injectors. Thank you Sapote as well for being so involved on the forum).
    Here are the results:
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
    Start : 10.08.2026 18:51:47.0
    Nr 1( 1) : 10.08.2026 18:51:47.4
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 38 00 26 .&
    EVAN_ISTWERT_EINH = Grad KW
    EVAN_SOLLWERT_EINH = Grad KW
    Nr 2( 1) : 10.08.2026 18:51:53.0
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 75 00 4B .K
    Nr 3( 1) : 10.08.2026 18:51:59.0
    apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    EVAN_VERSTELLZEIT_FRUEH_EINH = ms
    EVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 4( 1) : 10.08.2026 18:52:05.8
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
    Nr 5( 1) : 10.08.2026 18:52:20.7
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 0 00 00 ..
    AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    AVAN_ISTWERT_EINH = Grad KW
    AVAN_SOLLWERT_EINH = Grad KW
    Nr 6( 1) : 10.08.2026 18:52:26.2
    apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 49 00 31 .1
    AVAN_SOLLWERT = 55 00 37 .7
    Nr 7( 1) : 10.08.2026 18:52:31.7
    apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 165 00 A5 .¥
    AVAN_VERSTELLZEIT_SPAET = 205 00 CD .Í
    AVAN_VERSTELLZEIT_FRUEH_EINH = ms
    AVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 8( 1) : 10.08.2026 18:52:38.4
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
    Stop : 10.08.2026 18:52:55.0
    Dauer : 68.1 s
  • Abso
    Hello everyone, I found this post very interesting and I just tested it on an S50B32. Could someone tell me if my test is correct? Thank you.
    Test file : C:\EDIABAS\ECU\BMW_S50B32_VANOS_TEST.TST
    Start : 08.06.2025 10:44:35,0
    Nr 1( 1) : 08.06.2025 10:44:35,1
    apiJob("bmss501","ident","","")
    ID_EML = 0 00 00 ..
    ID_OBD2 = 0 00 00 ..
    ID_AI_NR = 02
    ID_HW_NR = 14 00 0E ..
    ID_MOTOR = S50_MSS50
    ID_SW_NR = 04
    ID_BMW_NR = 1406611
    ID_EWS_SS = 2 00 02 ..
    ID_LIEF_NR = 0000115852
    ID_PROD_NR = 971810576
    JOB_STATUS = OKAY
    ID_DATUM_KW = 20
    ID_BUS_INDEX = 00
    ID_COD_INDEX = 00
    ID_DATUM_JAHR = 97
    ID_DIAG_INDEX = 30
    ID_LU_MESSUNG = 0 00 00 ..
    ID_AIF_VORHANDEN = 1 00 01 ..
    ID_LAMBDA_STEREO = 1 00 01 ..
    ID_SG_HERSTELLER = 0 00 00 ..
    Nr 2( 1) : 08.06.2025 10:44:35,2
    apiJob("bmss501","STATUS_MOTORTEMPERATUR","","")
    JOB_STATUS = OKAY
    STATUS_MOTORTEMPERATUR_EINH = Grad C
    STATUS_MOTORTEMPERATUR_WERT = 7.200000E+001
    Nr 3( 1) : 08.06.2025 10:44:35,4
    apiJob("bmss501","STATUS_OEL_TEMPERATUR","","")
    JOB_STATUS = OKAY
    STATUS_OEL_TEMPERATUR_EINH = Grad C
    STATUS_OEL_TEMPERATUR_WERT = 4.300000E+001
    Nr 4( 1) : 08.06.2025 10:44:35,7
    apiJob("bmss501","STEUERN_EVANOS_FRUEHANSCHLAG","" ,"")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
    EVAN_SOLLWERT = 0 00 00 ..
    Nr 5( 1) : 08.06.2025 10:44:41,0
    apiJob("bmss501","STEUERN_EVANOS_SPAETANSCHLAG","" ,"")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 59 00 3B .;
    EVAN_SOLLWERT = 60 00 3C .<
    Nr 6( 1) : 08.06.2025 10:44:46,3
    apiJob("bmss501","STEUERN_EVANOS_VERSTELLZEIT","", "")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 142 00 8E .?
    EVAN_VERSTELLZEIT_SPAET = 174 00 AE .®
    Nr 7( 1) : 08.06.2025 10:44:52,6
    apiJob("bmss501","STEUERN_EVANOS_DICHTHEIT","","")
    JOB_STATUS = OKAY
    EVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
    Nr 8( 1) : 08.06.2025 10:45:06,9
    apiJob("bmss501","STEUERN_AVANOS_FRUEHANSCHLAG","" ,"")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 1 00 01 ..
    AVAN_SOLLWERT = 0 00 00 ..
    Nr 9( 1) : 08.06.2025 10:45:12,3
    apiJob("bmss501","STEUERN_AVANOS_SPAETANSCHLAG","" ,"")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 40 00 28 .(
    AVAN_SOLLWERT = 45 00 2D .-
    Nr10( 1) : 08.06.2025 10:45:17,6
    apiJob("bmss501","STEUERN_AVANOS_VERSTELLZEIT","", "")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 184 00 B8 .¸
    AVAN_VERSTELLZEIT_SPAET = 225 00 E1 .á
    Nr11( 1) : 08.06.2025 10:45:23,8
    apiJob("bmss501","STEUERN_AVANOS_DICHTHEIT","","")
    JOB_STATUS = OKAY
    AVAN_STATUS = VANOS-Einheit undicht, Messung abgebrochen
    Stop : 08.06.2025 10:45:38,4
    Dauer : 63,4 s
  • Tomba
    Cumbustion, you mean fuel contamination?
    Could be yes.
  • ac427
    pinging sounds more like cumbustion is not OK. Would check fuel trims and knock adaption too.
  • BMWfanz
    Originally posted by Deutsch View Post
    Tomba, thank you so much for the .tst file! Very easy to perform with tools that I already own!
    To keep the thread rolling, here are my results from the test, on a freshly rebuilt motor with all new chains, chain guides, vanos seals, etc. with a few dyno pulls and 1 race weekend on it.
    I may re-time it over the winter to get that last 2 degrees on the intake cam.
    Start : 29.10.2024 17:28:44.6
    Nr 1( 1) : 29.10.2024 17:28:44.8
    JOB_STATUS = OKAY
    Nr 2( 1) : 29.10.2024 17:28:50.2
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 58 00 3A .:
    Nr 3( 1) : 29.10.2024 17:28:55.7
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 263 01 07 ..
    EVAN_VERSTELLZEIT_SPAET = 226 00 E2 .â
    Nr 4( 1) : 29.10.2024 17:29:02.1
    JOB_STATUS = OKAY
    Nr 5( 1) : 29.10.2024 17:29:16.5
    JOB_STATUS = OKAY
    AVAN_ISTWERT = -1 FF FF FF FF ÿÿÿÿ
    Nr 6( 1) : 29.10.2024 17:29:22.0
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 47 00 2F ./
    Nr 7( 1) : 29.10.2024 17:29:27.4
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 219 00 DB .Û
    AVAN_VERSTELLZEIT_SPAET = 215 00 D7 .×
    Nr 8( 1) : 29.10.2024 17:29:33.8
    JOB_STATUS = OKAY
    Stop : 29.10.2024 17:29:48.8
    Dauer : 64.2 s
    Actually you don't need to retime engine- there is full diapason of vanos (from -2 to 58 (60 degrees) and from -1 to 47 (48 degrees). Starting position of cams will be zeroed with adaptations.
  • Deutsch
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    Dauer : 64.2 s
  • Bry5on
    So I had a question about the Vanos test.
    One of my cars is starting to have the marbles in a can sound at low RPM with a load on the engine. Sounds like pinging but it's a fresh rebuild. It's the same sign you're hearing cars when you run low octane fuel when you get the marbles in the canned sound.
    Doing some searching I came across several instances where they mentioned timing being off.
    I have never heard the pinging before until recently, so my guess is maybe it would probably go away if I reset Vanos adaptations and then probably come back
    So if I want to run the Vanos test, should I run it now and it's current state or should I run it after I reset adaptations?
    And would a successful vanos test mean that the engine is properly timed
    I also had these Shadow codes. I never saw a check engine light but I decided to check codes today and saw these Shadow codes. Inlet Vanos retard valve errors
    This sounds like the CSL tune on stock cams if your marbles are below 2800rpm or so at medium/high throttle. Cam offsets will not solve this. I believe the only way to eliminate it is to remap several of the fields in the CSL file itself beyond a simple tune. As Heinz mentioned, I have created maps that solve this and bring back stock drivability. I call them the mullet tune. If you’re interested, shoot me a PM.
