Steer Me The Right Way
    looking to get dealer quality laptop and software.
    Either buy a pre-loaded HDD or entire laptop with ISTA installed. Those will also have INPA and standard stuff like NCS,Tool32,WinKFP etc.
    This tool for all intents and purposes is really all you need and it's free, also you can do vanos tests with it plus datalogging and DME read/write.
    Hi all, For those of you who've been following on my journal you'll have known this is coming :) For many years those of us with E46 M3's have had to pay for tools to flash our DMEs. No longer, this app is FREE to use: Freeware license here Disclaimer Using any tool to write to/modify your DME is not free of risk. You should
    ISTA is dealer software, get an ICOM cable for the ability to do vanos tests.
    But just for the cost of a KDCAN cable you can do likely everything you need to do with Karter's program.
      I usually get by with Old Dell Laptop and INPA, BMW Scanner 1.4, and OBD Fusion (phone and blue tooth). Each one uses different connections, but i can scan and diagnose almost anything.
      good info here:
      This thread describes how I install and configure BMW Standard Tools, the suite of BMW software that includes INPA, NCS Expert, WinKFP, Tool32. I have my own custom way of doing this that is the shortest and simplest steps I could figure out. This set up is for E46 only. What is included...
      This thread is intended to contain all information and links for BMW Scanner 1.4. Background BMW Scanner 1.4 runs on Windows, and provides the ability to read/clear trouble codes, view live data, code settings, and test functionionality on most control modules found on BMW models produced from...
      If you have a smart phone or tablet, get an OBDII app and wireless adapter to see exactly what is going on with the engine fuel management system. A quality OBDII tool supports the following: Diagnostic Trouble Codes (DTCs) in Pxxxx format (such as P0171) Individual emissions readiness...
