SW updates for MSS54 and MSS54HP
    HI guys/gals.
    I recall seeing this information on M3F trying to return an MSS54 to stock with winkfp since i don't have the stock bin file (SW 211322002101-J429)
    anyone have the most up to date SW variants for
    MSS54:
    EURO
    ​​​​​​USA
    (coupe/vert?)
    MSS54HP
    EURO
    ​​​​​​USA
    (coupe/vert?)
    MSS54 and MSS54HP XDFs . Contribute to saildot4k/MSS54-XDFs development by creating an account on GitHub.
    Pretty sure all the binaries (full and partial) are there.
      Just do a ZUSB update in WinKFP.
        https://github.com/saildot4k/MSS54-XDFs
        To go from HP to a CSL clone, is it really as easy as just flashing on the bin? I've read that there's post flash tune updates required, assuming you don't have the CSL cams installed.
          Yup you do have to change some things if you don't have CSL cams, but flashing the terra/paffy binary will make your DME behave like a CSL DME. Note that it is not a true clone, as the boot sector is still HP. To achieve a full clone, you need to flash the full CSL binary (which includes the CSL boot sector) via BDM or directly onto the EEPROMs with a chip programmer.
            MSS54HP Euro 6spd is
            MSS54HP 7837805 7837780 211323002001J424
            I recently loaded and works well.
            '06 IB/BLK 6SPD PN66072
              I thought about going this route, but since the ECU its not the one that came with the car.
              would i used the VIN that is on the ecu, pull the file after flashing and delete EWS or is there another option.
                You don't need to worry about the VIN, WinKFP looks at the software that's on the DME before flashing the appropriate upgrade. Once you've done that you can pull the bin, delete EWS and away you go.
                  thank you Martyn this worked perfectly
