10 seconds sounds too long. In my E30 S54 as the pump was just under the rear seat, it was very audible when priming. I think ~2 seconds sounds about right. In which case I would doubt there to be a conversion, unless in milliseconds....Also, if someone DOES find it, and the XDFs are wrong, please submit a bug report or correct the XDFs yourself on github.
Fuel Pump Prime Time
Sorry I think you're right that ENDE isn't correct, that's probably something with the start transition.
If you get rid of the conversion on K_EKP_PERIOD the value is 2595 ms, 2595/1000= 2.6 seconds which sounds like the right spot
I've found more than a few of the time conversions to be incorrect as far as I can tell, my XDF has x*0.00321
I'd also be willing to bet EKP_LOWTIME_MIN should also have no conversion if it's in msLast edited by exodus454; 09-02-2020, 01:18 PM.
