Can the secondary air pump be coded out with NCS? If so, what ecu is it under and german name? Thanks. I would use martyn’s tool but it can’t pull the files from my ecu using the bmwflasher. It gives a bin file size of 0 and throws an error.
Secondary Air Pump
No, not possible.Originally posted by Mspir3d View PostCan the secondary air pump be coded out with NCS? If so, what ecu is it under and german name? Thanks.
maybe the interface? Try another tool or software or contact Martyn.Originally posted by Mspir3d View PostI would use martyn’s tool but it can’t pull the files from my ecu using the bmwflasher. It gives a bin file size of 0 and throws an error.
Kim's Chipster tool is free available and does a very good job at partial read/writes and checksumms.
