Paint Correction - 2006 IB E60 M5
    I recently corrected my friend's 2006 M5, and took some photos that I shared on IG, but since there's a detail sub-forum, and this forum could use some more content, I figured I'd post here as well. Maybe people will see this. Or not
    Click image for larger version  Name:	E60M5day103.jpg Views:	17 Size:	114.7 KB ID:	196788
    Car has a little over 100k, and it was pretty well taken care of. He did have the front bumper resprayed, but everything else is original and there are no serious dents/clearcoat failure/defects.
    I start with a typical car wash, but I use dish soap so as to strip anything on the paint. I used to also spray some iron-x type of decon products, but found them to be fairly useless if I plan to clay the car anyway. You can see water beading up - the car was already in good shape for its age.
    Click image for larger version  Name:	E60M5day104.jpg Views:	15 Size:	130.2 KB ID:	196789
    Next, I clayed the whole car. Most panels didn't have much, but the roof was the worst:
    Click image for larger version  Name:	E60M5Day203.jpg Views:	15 Size:	51.8 KB ID:	196790
    Unfortuantely, I didn't remember shots of the hardware and chemicals I used, but I'll lay it out here:
    I'm using a cheap 6" DA, with a 5" backing plate for more pressure - I prefer 5.5-6" pads versus 6.5"
    I used Griot's Fast Correcting cream (compound) and a cyan blue hydro-tech (eurofoam) Lake Country pad. I chose foam (as opposed to MF) as I didn't need to cut the car down that much anywhere.
    For the second, polishing step, I used Mother's CMX 3n1 which is a polish and sealent (CMX - sio2/tio2) on a seafoam green LC CSS pad. So the 2nd step was an AIO, but I stacked it the next day with more CMX.
    Also, before compound/polish, I always treat all plastic/vinyl/rubber with protectant and let it soak in. Below you'll seee the front bumper where there's lot's of plastic, but also the side grilles, and all window trims.
    Click image for larger version  Name:	E60M5night16.jpg Views:	16 Size:	79.8 KB ID:	196791
    Next, I'm going to show some BEFORE shots. Mostly, it's fine scratches/swirls, but some other marring like scuffs and waterspots/etching. All very common, and not that bad for a 2006 car.
    Click image for larger version  Name:	20221027_172005.jpg Views:	14 Size:	101.6 KB ID:	196792
    Click image for larger version  Name:	E60IBday323.jpg Views:	1 Size:	56.8 KB ID:	196834
    AFTER
    Click image for larger version  Name:	E60IBday327.jpg Views:	11 Size:	51.2 KB ID:	196837
    More coming...
    I took the plate off, but no other body parts.
    Click image for larger version  Name:	E60M5day116.jpg Views:	0 Size:	146.9 KB ID:	196833
    The back was the worst. Here's a pretty bad scuff:
    Click image for larger version  Name:	20221027_171905.jpg Views:	0 Size:	41.0 KB ID:	196828
    Click image for larger version  Name:	E60M5Day238.jpg Views:	0 Size:	72.6 KB ID:	196829
    Click image for larger version  Name:	E60IBday314.jpg Views:	0 Size:	87.4 KB ID:	196880 Click image for larger version  Name:	E60IBday315.jpg Views:	0 Size:	103.3 KB ID:	196879
    Roof RIDS
    Click image for larger version  Name:	E60M5Day221.jpg Views:	0 Size:	55.4 KB ID:	196830
    Click image for larger version  Name:	E60M5Day230.jpg Views:	0 Size:	72.2 KB ID:	196836
    Trunk Lid
    Click image for larger version  Name:	E60M5Day236.jpg Views:	3 Size:	112.4 KB ID:	196831
    Click image for larger version  Name:	E60IBday313.jpg Views:	0 Size:	61.5 KB ID:	196878
    Lip spoiler
    Click image for larger version  Name:	E60M5Day240.jpg Views:	3 Size:	94.8 KB ID:	196832
    Click image for larger version  Name:	E60M5Day243.jpg Views:	0 Size:	77.3 KB ID:	196835
    Passenger Doors
    Click image for larger version  Name:	E60IBday304.jpg Views:	0 Size:	74.5 KB ID:	196881 Click image for larger version  Name:	E60IBday303.jpg Views:	0 Size:	63.1 KB ID:	196882
    All done cutting her down. I wasn't disappointed by the foam in any arears, though I did have to put more heat into a few spots to clean it up satisfactorily.
    Click image for larger version  Name:	E60M5IBPolish05.jpg Views:	0 Size:	149.8 KB ID:	196883
    Next I'll polish it and seal it. The following post's pics will be after a 24 hour cure of the CMX.
      Click image for larger version  Name:	E60M5IBShoot (44).jpg Views:	0 Size:	109.3 KB ID:	196926
      Click image for larger version  Name:	E60M5IBShoot (8).jpg Views:	0 Size:	136.5 KB ID:	196930 Click image for larger version  Name:	E60M5IBShoot (15).jpg Views:	0 Size:	60.3 KB ID:	196929
      Click image for larger version  Name:	E60M5IBShoot (1).jpg Views:	0 Size:	126.4 KB ID:	196932
      Click image for larger version  Name:	E60M5IBShoot (3).jpg Views:	0 Size:	193.3 KB ID:	196933 Click image for larger version  Name:	E60M5IBShoot (29).jpg Views:	0 Size:	117.2 KB ID:	196925
      Click image for larger version  Name:	E60M5IBShoot (39).jpg Views:	0 Size:	198.9 KB ID:	196927 Click image for larger version  Name:	E60M5IBShoot (11).jpg Views:	0 Size:	177.0 KB ID:	196931 Click image for larger version  Name:	E60M5IBShoot (48).jpg Views:	0 Size:	194.1 KB ID:	196928
      I love this ^ last one. Look at IB in the sun! Never seen it so strong of a royal blue.
      I really enjoyed this one. Always nice to work a new paint color, esp the pretty IB.
      If anyone in Socal wants this done to their car for a very reasonable price, PM me.
        Very nice work and my favorite color! Only reason I see using de-iron or de-tarring is for decontaminating before taking an abrasive like clay bar/mitt to the paint. To reduce the amount of scratching before polishing is to preserve as much clear coat as possible. Best to be taken into consideration on older vehicles with original paint or low micron count clear. Otherwise great for wheels and brakes
          Amazing work! Sent you a PM.
            I thought I’d never say this about a Bangle designed car, but that does look terrific. That’s a nice job in removing the swirl and crazing marks in the paint-work.
              Thanks. I still don't love the styling, but it's grown on me, and it looks really good in person. What I thought looked a bit ridiculous 15 years ago, now seems tame compared the the latest stuff; it's aged well.
