I have some splitter mounts I’m selling
    Figure I’d post this here for the track people.
    I cut out some splitter mounts from scraps of carbon. The holes will be drilled. Does not include hardware and may need a little trimming. They fit between the front crash bar and frame rail.
    I welded a coupler nut to a steel tab which was riveted and bonded. I can provide the coupler nut and do the welding for an additional charge.
    $45 shipped for a pair.
    this is the finished part that I use.
    Very cool. Can you show us a picture of your splitter?
      Shows the final mounting...
      The Red Drift ///Machine - NA M3 Forums
        Here is the splitter and mounting
        This is the two outer mounts. Ebay shock and clevis joint ($40) and pins/clips from McMaster Carr
        Click image for larger version  Name:	5FAECE23-2F49-42C1-94FB-DDF5967FDEF4.jpg Views:	4 Size:	91.0 KB ID:	252864
        Click image for larger version  Name:	E2203D50-8737-47C5-B8C1-DB204EDC705A.jpg Views:	4 Size:	161.9 KB ID:	252865
        Here are the primary mounts. There is a coupler nut welded to a tab which is riveted and bonded to the carbon plate. Then there is an aluminum turnbuckle with a spherical eye at the bottom. Attaches to the splitter using a pin and clip. Might be hard to see but I installed rivet nuts for the M6 bolts.
        Click image for larger version  Name:	97887959-2C8C-48FB-BAEB-8CF2539E3627.jpg Views:	4 Size:	180.9 KB ID:	252868
        I bonded aluminum T channel to the splitter. Also used a two piece sleeved screw thingie...forget the name. Have to have the thickness spot on though - WITH LOCTITE!!! All of this stuff vibrates a lot so things come loose.
        The pin goes through and voila - splitter is secured!
        Click image for larger version  Name:	762C416D-B8BC-4C1D-8717-0F7C9BCE96BE.jpg Views:	4 Size:	170.1 KB ID:	252869
        Here's splitter...
        Click image for larger version  Name:	0176BA17-4BFD-4A46-A4F4-18A3C35C50E0.jpg Views:	4 Size:	126.7 KB ID:	252866 Click image for larger version  Name:	CFC744AA-BC45-456D-A38D-FFA52C2E58D0.jpg Views:	4 Size:	144.3 KB ID:	252867
          Here is the back mount. It is c-channel aluminum. I replaced the OE hardware and bonded an M8 nutset to the backside. The reinforcement plate is carbon so this works really well. While there is load on this point, the splitter is being pushed upwards - the level effect on the front half of the splitter. The OE aluminum plate will also be fine.
          All of the parts were bought from McMaster Carr or eBay - Spent about $100 on everything.
            Very cool - thanks for sharing. I read your build thread and quite impressed. Someday - maybe for my car.
              This is very cool! Did you make that yourself? What's the weight saving?
              2003.5 Titanium Silver / Black 6M/T (Gone)
                Made it myself. Saves about 4 lbs but it’s stiffer. That is a lot of layers of carbon. I think I could make it even lighter with added stiffness by using a core material, just haven’t tried yet. I'd also leave more material on the front edge so I could bond the c-channel.
                Click image for larger version  Name:	01D9F246-809B-449D-B268-248E0CBA6673.jpg Views:	0 Size:	288.8 KB ID:	253766
                Click image for larger version  Name:	6D15BEF2-1FF1-4EDB-8174-87FB1D7A7B1F.jpg Views:	0 Size:	176.4 KB ID:	253765 Click image for larger version  Name:	D75AAF05-3728-438C-9B66-2771AE211AF1.jpg Views:	0 Size:	170.4 KB ID:	253764
                  Love it! If you do decide to make another one and want to see me that one let know!
                    I'd rather just make a new one for you. The one on the car has endured two major oil leaks. The top side cleans up really well, the bottom which is the textured matte side doesn't.
                      Do you have to tape the chin spoiler area or how do you get enough torque on the stanchions to keep a seal?
                        The supports are adjustable so the splitter is flush against the bumper. I can't be 100% sure if the splitter isn't flexing downward but I've never scraped the front of the splitter under braking from high speeds. I highly doubt it because I'd have a ton of pebbles and rubber to clear out from the reinforcement plate if it was creating a gap.
                          Ok! The time is now. I’ve got a BW rear wing on order and want to sort out what to do about a splitter up front.
                          The goal is to learn…through a process how aero changes the game.
                          bigjae46 are you still using this splitter mounting setup? I’ve been looking at commercially available splitter mounts and only finding the BuildJournal option available…if that’s even a real thing.
                            Yes, no change to my splitter mounting. Took a big hit earlier this year and nothing bent.
                            I'd stick with something that is steel. Aluminum bends too easy. But you can also get all of that Buildjournal stuff from eBay for half the price.
                              My WRL buddies are using the build journal mounts, I don't think they are having issues with them.
                              I put in the racebred mounts, I flipped them around so the pin can be pulled from the wheel well by reaching in. Makes it a bit harder to slide the splitter back on. They seem really robust and are pretty heavy.
