This damned front splitter...think I have it figured out. I was trying to stay away from using steel to mount the splitter but aluminum is too soft.
I welded some threaded inserts onto a steel plate. The mounts are height adjustable.
I attached the brake ducts to the front reinforcement bar. I used some L brackets from home depot and bolted them on using riveted nut-serts.
First two attempts at the carbon splitter...let's say I learned a lot. Biggest issue was the top had a lot of air trapped in the finish so the carbon didn't get completely wet out. I punched holes in the foam core and got much better results...
Better mounting. Using some binding posts and a urethane 2 part adhesive to mount the hardware to the splitter. Here it is! Comes on and off much easier.
