The Red Drift ///Machine
    This damned front splitter...think I have it figured out. I was trying to stay away from using steel to mount the splitter but aluminum is too soft.
    I welded some threaded inserts onto a steel plate. The mounts are height adjustable.
    I attached the brake ducts to the front reinforcement bar. I used some L brackets from home depot and bolted them on using riveted nut-serts.
    First two attempts at the carbon splitter...let's say I learned a lot. Biggest issue was the top had a lot of air trapped in the finish so the carbon didn't get completely wet out. I punched holes in the foam core and got much better results...
    Better mounting. Using some binding posts and a urethane 2 part adhesive to mount the hardware to the splitter. Here it is! Comes on and off much easier.
      nice build
      Build Journal - E46 M3 CSL Conversion
        Looking good! Sucks about the engine problems, hopefully that won't be an issue now.
        Japanrot Red E46 330i Msport k24/dct/turbo Build Thread
          It does suck but its not THAT bad. At least I know what to do now. The engine has been running pretty well.
          UPDATE:
          The bad news...not going to be ready for the first event of the year. Seat, brake rotors, and harnesses did not arrive in time to get a tech inspection for the NASA event. The upside is I'm going to be playing lots of ice hockey this weekend
          The goal - get to 2550 lbs dry so I can install a 1.5' dia x .095 wall roll cage which meets NASA and BMWCCA rules (SCCA too...I think) and a carbon roof with some margin of safety. Both should cut out another 70lbs.
          I got my scales back...lots of people like borrowing them. Helped out a team get 5th overall in a WRL race!
          Here are the corner weights with me in the car, no pass seat, AGM battery and 38L of fuel.
          First off...I'm fat right now. I'm adding 220lbs incl helmet and hybrid device. Should be closer to 180-190. Got some work to do there. Happy about the 50.3 cross weight. Still 51.2/48.8 front to rear. The goal is to get to 50/50 which is going to be tough.
          2761lbs
          65lbs of fuel (38l * 1.71lb/L)
          2696 dry - that is more than I expected. 46 lbs is the battery, I can install a lithium battery which saves 42 lbs. If I run Hoosiers instead of NT01s - saves another 16 lbs
          2638 lbs post battery w/ hoosiers. So 88 lbs to go, have to lose almost all of it over the front axle. I've spent very little money in weight loss parts but now its time to open the wallet
          Carbon fiber hood, headlight blanks, seat floor mount adaptors, and front reinforcement plate - 27 lbs
          CSL/carbon air box - 9lbs
          Hotchkis Sway to replace the OE bar - 4 lbs
          Containment seat - 4 lbs
          Muffler delete - 8 lbs
          Tilton clutch/flywheel - 5lbs
          That's 57 lbs, still have 31lbs to go.
          Probably should have did this in the first place but it going to make the most sense to use the BMW C&R oil cooler which saves me about 6 lbs.
          Now 25 lbs to go and the options are getting less and less...
          Carbon fenders - 6 lbs
          Rear coilover/convert upper control arm to link - 5 lbs
          Carbon trunk lid - 5 lbs
          Carbon rear floor brace - 3 lbs
          Carbon muffler hanger mount/cross brace - 1 lbs
          ECU relocate/Dash Trim - 3 lbs
          Its not going to easy. I figure that I'll have to find another 10-15lbs in the end to account for little things that get added back (paint, hardware, etc) and adds weight. This should make it the lightest E46 M3 in existence!
          I had Paul Claude update my tune to account for the headers. The AFRs were high and I had a 30hp dip between 4k to 5.5k rpm during my last dyno in 2018 which I think hurts me quite a bit. The engine is in this range when I start to turn into most turns. It feels like the engine is lugging through the corner and then the VTEC kicks in. It gets worse as the IATs climb. I hope that I get a more linear power delivery as I roll back onto the throttle to exit. I need a little more power...I keep getting run down on the straights.
            One last video from COTA. Its an interesting power vs handling battle.
            MSR Cresson 3.1 in Nov. Best lap of the weekend was a 2:22.9 which I'm really happy with. I hope with some weight loss, aero improvement and a little more midrange power coupled with better driving I can be in the 2:20's.
              Finished the splitter up. Riveted some aluminum T bars as a reinforcement and UHMW blocks on the bottom as skid plates.
              Installed Turner monoball RTAB and FCABs.
              Performed a corner balance and alignment. Perfect 50/50 cross weights and a 52.5/47.5 F-R weight distribution. Then I dialed out some toe on the rear tires (.11 each side which is about .03 from min spec.
                I have a 2021 goal of getting into the 1:40s on NT01s on my home track, MSR Houston. PR so far is 1:43.9.
                I'm at about 2900 lbs with 275/40R17 NT01s. Ran a 1:41.269 and consistent 1:42s to 1:43s. I also measure my best lap against my virtual best to get an idea of how consistent I am. On Sat, I was .1 sec off my VB and .4 sec on Sun. Very happy with that! I put in fairly consistent sector times lap over lap, with .5 sec per sector (about .5-.75 miles). I have 5 things I can improve with my driving which I think can net me 1 more second. My next effort is to reduce drag, especially in the front wheel wells. And as always...more weight reduction.
                  Here are some advices to remove weight.
                  -You can get composite doors. Even if you gutted the OEM doors they are still heavier than composite doors.
                  -you can remove all the undercoating under the car and stitch weld all body joints. I did that on my last track car build. It’s a lot of work but help to get a stiffer chassis
                  -if you are going to redo the cage, you can cut all the sheet metals inside the A-B-C pillars and quarter panels. Car will be like a semi-tube frame car. And to get rigidity back you make gussets from cage to A-B pillars. I did that too on my last race car build. I was able to get the tubes touching the inside of the A pillars /the visible sheet metal visible from outside.
                  -you can relocate the battery in the passanger side footwell area and eliminate 1 big wire.
                  -you can do a custom side exit exhaust and save some length of exhaust piping and probably get better exhaust flow.
                  -while doing the side exit exhaust setup, you can redo the exhaust setup with Titanium parts from Vibrant to save even more weight
                  I have pictures of all of this if you want
                  GT4 Composites
                  2003 BMW E46 M3 Laguna Seca Blue / LSB 6mt
                  2006 BMW E46 M3 Estoril blue / Black 6mt
                    I’d like to see what you did with the A and B pillars.
                    I want to get weight off the left front corner. I am considering a carbon fender and door on the left side only.
                    I’m at 52.5 fr weight distribution. I don’t want to do the side exit right now because it would take more weight off the rear. It’s on the list though.
                    What about using aluminum for the exhaust?
                      Pretty sure Titanium will be stronger than Aluminum with thinner wall so probably lighter too and can handle heat better than alu too. But will be more expensive.
                      I think for our level of preparation and driving skills (we are building cars at home and doing track days for fun, not for a living), you will be able to feel weight reduction more than weight distribution. So if you are able to remove 100lbs, you should be able to feel it a little bit during acceleration, cornering and braking vs the difference from 52.5/47.5 f/r to 50/50 f/r.
                      Also, you are talking about carbon fiber parts. Don’t get fool by carbon fiber parts, a lot of those parts are made for look only and aren’t that light at all. I had a single side Vorsteiner hood 10 years ago and it was heavy. I am trying to work with the guy who’s doing the Mile End composite parts to do E46 M3 track/race specific parts in the future. He has the knowledge to do crazy lightweight parts.
                      GT4 Composites
                        Couldn’t tell a big difference when the car was around 3000lbs dry. Funny thing was I’d used to forget I had a passenger. Now that it’s around 2600lbs dry with aero...you can feel 50lbs. The car is far more sensitive.
                        Improving the weight from 53.75 on the front to 52.5 has made a significant difference. I want to keep going that direction for now.
                        As for carbon fiber...true. Many parts are FG chop mat underneath. I’m making my own CF parts so I can control weight and strength...or at least to the best of my limited abilities.
                        Target weights -
                        Left front door - 10lbs
                        Fenders - 7lbs
                        Roof - 4lbs
                        Hood - 8lbs
                          nothing changed since e46fanatics, carry on!
                            I have an ultimate goal of being into the low 1:40s on NT01s CCW at MSR Houston in NASA T3 trim...someday I will run NASA. Not quite ready yet for show time. I know the car is easily there, the issue is the driver. I've been driving this general line/brake point for awhile with some adjustments in the sweeper and gut check. I'm generally a conservative driver especially on corner entry. Mostly because the last thing I want to do is wad up the car. I know there's time in the brake zones. So enter coaching. Really don't have the fun budget to hire a coach on a regular basis. I'd have to give up ice hockey...and I've give up driving before I give up hockey. I stumbled on Racer360. It is $100 for a lap...figured I would give it a try.
                            Jaw Bone (T1) and Carousel (T2)...I know, I know. Not surprised by anything he said. But if definitely helps to have someone explain some detail on why. Without that, not sure I would be that much more committed to making the change.
                            I've always straight line braked into T3, throttle and then brake into Diamond's Edge (T4 and T5). Its become a habit and making this one braking zone was not on my radar. Wow.
                            Sweeper (T7) - Again, not surprised but it is helps A LOT to hear the feedback from someone else.
                            I will definitely use Racer360 again. There are limitations, you can't go right back out and apply the feedback, I have to wait 5 weeks. I'm not sure you will get any feedback beyond what an in car instructor can tell a novice or even an intermediate driver. I think it is harder to get a critical look at your driving for an advanced driver (duh). For those on a limited budget, enter Racer360. It won't make you into a pro quickly but it is a good tool to overcome any development plateaus.
                            So now I have 5 things to work on the next time I'm driving MSRH CCW with a clear goal. I think I can get into the 1:39s.
                              Did an event at MSR Houston going the same direction post coaching. I was unable to lower my PR. Partly weather (warmer) and partly reliability - had TPS issues. I know better...should have had spares. The Red Drift ///Machine still was unable to outpace most others and run 1:47-1:48 in limp mode.
                              I did work on a smoother entry into T2 and one brake zone into T4 and T7. Still playing with T2, the rear end gets light and wants to come around. The car is on the edge and my min speed is lower. I think I need to enter wider. After analyzing data, I'm 10-15 mph faster in the braking zones into T4 and T7. I can still carry more speed. I think I would have lower my PR if I had some more laps.
                              Overall, very happy with the performance of the car. Just need to stop having stupid stuff go wrong - DS CV, TPS sensors, O2 sensor, water pump, PS rack seal....
                                Finally got to run Eagles Canyon Raceway. Feels like I have unfinished business. Ran 3 full sessions, first one was wet. If you dropped two wheels, the track made you stop and get towed off to avoid tracking mud onto the surface which apparently degrades the drainage. So let's say I wasn't really pushing.
                                Just made it into the 2:09s by my 3rd session and then had an issue. When I replaced the brake pads...I didn't remove the master cylinder cap. By the 3rd session, I'm certain brake fluid was coming out of a weep hole in the cap (there is one). I eventually started smoking from brake fluid hitting the exhaust. It was very weird...I was like damn not another PS leak. But the smoke smelled like BBQ? I didn't say anything until someone else said I was smoking and it smelled like BBQ. It was a mess...about 3 gallons of brake clean later...its all cleaned up. But I didn't get many laps after my 3rd session.
                                I have an easy half to one second in every braking zone. I think one more weekend I should be pushing 2:03 - 2:04 on NT01s.
