Aero Testing
An option for sure. Might even be able to adapt the E9x cooler to work.
Would be interesting to see where to duct the hot air though. Under the car E9x style sounds fancy, but I'd be afraid of messing it up and introducing lift.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I think the middle hood vent is helpful...with a gurney flap. The hood bulge is in a terrible spot if you want to retain it...which I do. I somewhat still care how it looks and how many dudes it will attract. I'd do a test but my local landfill...I meant track is closed for maintenance. I'll put it on the list for fall.Originally posted by CrookedCommie View PostYes I'm thinking blocking it off and skip installing the middle hood vent. I'm wondering if I should also cap off the pass side brake duct instead of venting it to the header side engine area.
I have the same question. Ultimately, I want to make ducting to vent the radiator out of the hood...maybe as far back as the hood bulge. Then I can stack a large oil cooler on the back of the radiator to maximize cooling, aero efficiency, and minimizing weight (of course). This is the main reason why I started down this path of aero testing. I'm still in the early brainstorming stage and open to ideas..
