Originally posted by bigjae46
Track Video Thread
I saw it coming, I was working on carrying speed through T5 and then coming into T6 if I don't plan my downshifts with my brake input properly it upsets the car and looses grip. I didn't want to go off side ways so I just committed to going for a ride ð
Dang...at least you didn't go flying off there sideways and out of control. That turn is scary.Originally posted by George Hill View Post
1500, wow!
Nice laps. I was there too, still learning my new setup, but very fun on the 3.1. And I didn't get any data all weekend, but a buddy caught me mowing the grass. ðĪŠ
1500, wow!Originally posted by Wernd View Post1500lb rear springs
Do you normally run with Driver's Edge? I normally do the 3.1 but I've got too many events coming up. Need a break.Originally posted by Wernd View PostFinally after 3 years I have the car handling close to how I want it! This was after talking to a fellow instructor from the Windy City chapter and making a trip to Doghouse Performance located at MSR Cresson.
Big changes were wavetrac diff, 1500lb rear springs, and a proper doghouse alignment, at which point they recommended I drop my MCS canister pressure to 170psi. Car was amazing but had a bit too much roll so they suggested taking the front canisters to 180, which fixed the issue.
Anyway here's the video of a few laps
https://youtu.be/2RssvjXNxi0?si=psy4R58UfvdEdEs0
New PB at my local track, still on those used 245 A052s. They gave up the ghost a session after this one. I want to do a 1:45 here on street tires. Almost there.
Biggest slip and slide bloopers from that.
You can roast 3rd gear with 200tws!
How much track out? All of it
Big bend and rattlesnake - have an easy second probably in each turn. Entering ricochet, I really need to left foot brake there because I'm not trying to scrub speed...just want to get some weight on the front tire so it turns. But that is not worth much time.Originally posted by nytgamgingcs View Post
Good stuff, where do you make up the most time here, and where do you lose it? I'm thinking of trying cresson next season
I am much more comfortable on the new side - 1.3 mile course.
The 3.1 mile course is awesome! I think it is the best track in TX. The 1.7 mile...it is hard to justify towing my car 4.5 hours from Houston to drive the 1.7.Last edited by bigjae46; 01-17-2026, 06:39 PM.
Tire puncture at Sebring at 115mph through Bishops bend!
A few others here: https://www.youtube.com/@CaliMotorsp...neering/videos
Z4m coupe racecar: 3150lbs wet, race fuel qty with driver
Square 295/30/18 Hoosier r7s
Euro headers: 1.625" Primary, 2" dual collector, Running to dual 2.5" catless midpipe/x pipe.
E85 conversion (walbro 450, 650 FIC injectors)
Turner motorsports CSL intake, with Intake Air temp sensor moved to bell of intake (not body where TMS has it).
12.5:1 CR CP pistons (87.25mm bore (.25mm oversized), CP rods (stock stroke 91mm) (3.26L displacement)
288/280 12.5mm lift Schrick Cams and DLC coated followers
stock vales, bmw performance 9k rpm springs (supertech SPRK-2521/BM 24)
ported/polished intake and exhaust ports (minor head work)
Bimmerworld Dual plate tilton clutch/ ltw flywheel
â
