If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I use just the front on soft. I run flat ride with Ohlins, spring rates are 375, 672.
I'm assuming you used the FCM spreadsheet, what FRC % does that end up at?
Yes, it's about 72.5. Also to clarify, when I said I just use the front, I use the front Turner bar, but kept the stock rear, so rear is present.
Do you find that's neutral-ish at the limit? Are you running square tires?
I run square. It's a bit playful, but I've gotten used to it. I would run on med setting (which would up front roll couple to 74% or so with 375/672), especially because I'm looking to drop the front rate to 350 (would up flat ride from 3% with 375 to 6% range with 350) while changing FRC by a few %, but with bar on med with 350, FRC would be around 74%.
I prefer a playful car, so there is a degree of personal preference here too for setup.
