Turner Motorsport Sway Bar Kit 30mm/25mm
    I'm considering the Turner Motorsport Sway Bar Kit for my track car project. Any opinions?
Name:	sway bar kit.JPG
    Instagram: M3Journal
    i run these and love it.. No issues in the past 3 years.
    Instagram: @_Frank_Stone_
      Thanks for the feedback! What setting are you using?
        I use just the front on soft. I run flat ride with Ohlins, spring rates are 375, 672.
        Youtube DIYs and more
          I'm assuming you used the FCM spreadsheet, what FRC % does that end up at?
            Yes, it's about 72.5. Also to clarify, when I said I just use the front, I use the front Turner bar, but kept the stock rear, so rear is present.
              Do you find that's neutral-ish at the limit? Are you running square tires?
                I run square. It's a bit playful, but I've gotten used to it. I would run on med setting (which would up front roll couple to 74% or so with 375/672), especially because I'm looking to drop the front rate to 350 (would up flat ride from 3% with 375 to 6% range with 350) while changing FRC by a few %, but with bar on med with 350, FRC would be around 74%.
                I prefer a playful car, so there is a degree of personal preference here too for setup.
                  Awesome, appreciate the feedback.
                    Great feedback, thanks gents!
