Hello,
Fairly new here! Not my first M3, but the first that I am trying to set up for some track day events (<10/year), and hoping to...
Search Result
85 results in 0.0048 seconds.
Keywords
Members
Tags
Trunk lock cylinder
Hi all,
Previous owner had replaced the trunk lock with an aftermarket backup camera. I would like to convert this back to a lock that is...Last edited by Atreezy; 06-14-2023, 07:35 AM.
Third Brake Light Seal Replacement
Does anyone know of a way to replace the seal on the third brake light? All my LEDs work properly or I would simply replace it. Just wondering if there...
Stripped FCAB Bolt Hole Suggestions
Welp, thought I'd replace the FCAB's with new OE while I was doing some other suspension work and upon taking the bolt out for the front right lollipop...
Vanos timing question
I'm at the end of my Vanos refresh.
I've been watching the videos in the Vanos thread here on the forums
I've also been following...
CSL Air Intake Temp Sensor Wire Diagram
CSL Air Intake Temp Sensor Wire Diagram...
Rear Subframe Install - DIY
M3forum member installed the Subframe kit along with Turner's instructions....
CSL Console - routing the side mirror control
CSL Console - routing the side mirror control...
CSL Roof install - Conversion DIY
Converting standard M3 to a CSL roof M3 DIY....
CSL Front Door Airbag Delete
How to install CSL door cards and remove the side airbag....
Rear differental fluid change
Old DIY for how to change the rear diff fluid on your E46 M3...
CSL Airbox and Air Duct install Guide
Here are threads from the old M3 forum on how to install the CSL airbox and the ducts if you have them....
- Likes 7
BMW CSL Roof install instructions
BMW official CSL installs instructions. The attachment has pictures and guides.
BMW TIS Home › 3' E46 › M3 CSL (S54) Coupe...
