BMW Injector Cleaning/Flow Test Service
    As the title says, I want to offer Injector Cleaning and Flow Testing to the forum members. I can do all top feed injectors but I have only worked on S54 injectors till now.
    I can perform injector leak down tests, spray pattern analysis, static and dynamic flow testing (can monitor injector flow across an RPM sweep). I will also ohm test all injectors and provide a before and after data sheet including flow test results.
    The service is $10/injector.
    I can also replace the O-rings, filter baskets and pintle caps for an additional $10/injector.
    I am located in North Carolina and can turn a set of injectors around in 3 days or less. If injectors need rebuilt, this might add a couple of days depending on replacement parts availability.
    In addition to the injector service fee, you would also be responsible for shipping both ways, please make sure to include a return shipping label when you send me your injectors.
    I will accept paypal - [email protected] (+paypal fee unless sent thru friends and family) or venmo - [email protected]. I will send shipping instructions once payment is received.
    Let me know if you have any questions.
    Lou
    Where in NC are you located?
      PM sent
      Just a thought - up your price to cover the PP fee and accept G&S only. That way you can be used as business income and you can deduct expenses. But if you’re unsure…consult with an accountant.
        High Point
          Originally posted by gheorghe View Post
          High Point
          I am in charlotte, so you are close. good to know. Do you work on E46 as well ?
            yes, I do all of my own work on my car. What work do you need?​
              Where in Charlotte? I'm in Charlotte as well.
                Thanks for setting this up. Will get with you once I have a chance to pull injectors.
                  Just asking if I need anything, I work on my car as well. Sometimes little help is good ​
                  I am in Waxhaw
                    Absolutely, let me know if you have any questions and if you ever make it up to the triad area
                      I am in Waxhaw
                      Roger. I'm near NoDa.
                      Are you in our local E46 M3 WhatsApp chat?
                        Surething!
                        I am not aware of that, I recently moved to this area. What is the group name ?
                          Surething!
                          I'll PM you. I don't think you'll be able to find it. Welcome to Charlotte, btw.
                            Thanks
                              Quick response and quick turn-around.
                              Highly recommend!!
                              Budget CSL MAP Conversion
