M3 S54 Cooling System Hi-Temp O-ring Kits!
    Complete set of Hi-Temp Silicone and Viton O-rings for the Entire S54 Cooling System. Also comes with the Power Steering, SMG Reservoir and Expansion Tank Cap O-ring's!
    Replace the factory Buna orings with higher quality Hi-temp Silicone and Viton O-rings. These O-rings have higher temperature rating and more resistant to compression set.
    Click image for larger version  Name:	IMG_E0979.jpg Views:	0 Size:	107.1 KB ID:	59396
    Click image for larger version  Name:	IMG_7007.jpg Views:	0 Size:	263.4 KB ID:	216231
    1- Temp Sensor- 1
    2- Bleeder Screw- 1
    3- Exp Tank Return Line- 1
    4- Water Pump Lines- 2
    5- Exp Tank Cap- 2
    6- Exp Tank & Heater Core Hoses- 5
    7- Radiator Hose Fittings- 2
    8- Water Pump Pipe to Block- 2
    9- Power Steering/SMG Caps- 2
    10- Water Pump Tstat Housing- 1
    Kit includes 2 squeeze tubes of Super Lube and 19 O-rings.
    19 O-rings and Lube for $50.00. Shipped via Priority 3 Day.
    Please send funds via PayPal as a gift or add $1.50 to cover the Fee to
    Mrdestny@yahoo.com.
    Available on eBay, I have 100% Feedback so buy with confidence! Over 100 sets sold with No Issues!
    https://www.ebay.com/itm/296838666042
    Viton is a synthetic rubber and fluoropolymer elastomer that is used in O-rings and other molded or extruded products. It offers the best fluid resistance of any commercial rubber. At high temperatures, Viton retains good mechanical properties compared to other elastomers. It remains substantially elastic and is resistant to oils and chemicals at elevated temperatures.
    With its low permeability to a broad range of substances, Viton resists degradation from a wider variety of chemicals and fluids such as fuels, lubricants and most mineral acids. Other mechanical properties include good resistance to compression, resistance to atmospheric oxidation, sun, climatic conditions, even fungus and mold. Viton displays good electrical properties, too, in low voltage, low-frequency applications.
    As a sealing option, the crucial difference between Buna and Viton is the temperature range the materials function in. Viton is the choice over Buna for high-temperature applications. Viton seals hold indefinitely at temperatures up to 400°F and can last up to 48 hours at temperatures up to 600°F. Buna is effective to 250°F.
    Hi-Temp Silicone O-rings are excellent seal materials for static, high temperature applications. Featuring outstanding flex and fatigue life, ozone and UV radiation resistance, physiologically neutral and insulating properties with a temperature range as low as -70 and up to 450 degrees fahrenheit.
    Super Lube Info:
    https://www.super-lube.com/Content/I...ose_Grease.pdf
    Super Lube® Grease is a patented synthetic heavy-duty, multi-purpose lubricant with Syncolon® (PTFE). Synthetic base fluids and the addition of Syncolon® (PTFE) micro powders combine to form a premium lubricant that provides longer life protection against friction, wear, rust and corrosion. Machinery lasts longer, downtime is reduced and productivity is increased.
    Super Lube® Grease is a NSF registered Food Grade lubricant, rated H1 for incidental food contact. Meets former USDA (H1) guidelines.
    Super Lube® Grease offers good mechanical stability, does not evaporate or form gummy deposits. It will not melt or separate. There is no Silicone in Super Lube® Multi-Purpose Grease with Syncolon® (PTFE).
    Click image for larger version  Name:	92fe4890b685949fcbdc61326ab3e10c.jpg Views:	0 Size:	68.9 KB ID:	216234
    Click image for larger version Name:	IMG_6824.JPG Views:	0 Size:	183.7 KB ID:	59391 Click image for larger version Name:	IMG_5605.jpg Views:	0 Size:	26.8 KB ID:	59389 Click image for larger version Name:	379933_x800.jpg Views:	0 Size:	28.1 KB ID:	59388 Click image for larger version Name:	379939_x800.jpg Views:	0 Size:	18.9 KB ID:	59390
    Click image for larger version  Name:	IMG_E0026.jpg Views:	0 Size:	183.5 KB ID:	216232 Click image for larger version  Name:	IMG_0869.jpg Views:	0 Size:	176.8 KB ID:	216233
    Click image for larger version  Name:	IMG_E0846.jpg Views:	0 Size:	78.1 KB ID:	216235
    Evolve Eventuri
    Bump...
    Evolve Eventuri
      Got mine for future cooling flush! Good to have since OEM cooling hoses from CRP (Rein) have, reportedly, weak orings.
        Could bad O-rings be a cause for Coolant Leak? Have a leak coming from somewhere. Removed the Radiator to see if that was the culprit. If so, I will be interested in these for sure. Thanks in advance.
          It could be yes.
          I replaced my water pump and orings I bought from ECS. They sent two different sized orings for the small water pump pipes which caused it to slightly leak coolant when the car was off. It caused the system to suck air when running which caused over pressurization. I originally thought I had a blown head gasket, luckily it was just a undersized oring which in turn led me to putting this Hi-Temp Oring kit together.
          Evolve Eventuri
            Bump...
            Evolve Eventuri
              Bump...
              Evolve Eventuri
                Bump...
                Evolve Eventuri
                  Time to do the Cooling System! Hi-Temp Silicone and Viton O-rings.
                  Evolve Eventuri
                    Bump...
                    Evolve Eventuri
                      Do any of the ones you have fit the hose that goes from the heater core to the engine? I have a leak there
                        I was working on adding those to the kit. I have two different sizes I can send you for Free if you provide some feedback on fitment. PM me...
                        Evolve Eventuri
                          Click image for larger version  Name:	IMG_E0979.jpg Views:	126 Size:	107.1 KB ID:	59396
                          1- Temp Sensor- 1
                          2- Bleeder Screw- 1
                          5- Exp Tank Cap- 2
                          19 O-rings and Lube for $48 Shipped via Priority 3 Day.
                          Please send funds via PayPal as a gift or add $1.50 to cover the Fee to Mrdestny@yahoo.com
                          Now available for Sale on eBay! I have 100% Feedback so buy with confidence.
                          BMW-E46-M3-S54-Hi-Temp-Cooling-System-O-Ring-Kits-and-More!
                          As a sealing option, the crucial difference between Buna and Viton is the temperature range the materials function in. Viton is the choice over Buna for high-temperature applications. Viton seals hold indefinitely at temperatures up to 400°F and can last up to 48 hours at temperatures up to 600°F. Buna is effective to 250°F. However, it can effectively seal mechanical objects at low temperatures to –22°F. Viton seals are rendered ineffective at temperatures below -5°F, with the material becoming hard and inflexible.
                          Super Lube Info:
                          ------------------------------------------------------- "OLD KIT" -------------------------------------------------------------
                          1- Temp Sensor- 1
                          2- Bleeder Screw- 1
                          5- Exp Tank Cap- 2
                          6- Radiator Hose Fittings- 2
                          7- Water Pump Pipe to Block- 2
                          8- Power Steering/SMG Caps- 2
                          9- Water Pump Tstat Housing- 1
                          Evolve Eventuri
                            count me in for a set!
                              Bump...
                              Evolve Eventuri
