Bump...🤙
M3 S54 Cooling System Hi-Temp O-ring Kits!
Might as well do it now while my engine is out. Ordered!Last edited by SteelGreyM; 09-03-2020, 09:18 AM.
Got it Thanks...😎Originally posted by SteelGreyM View PostMight as well do it now while my engine is out. Ordered!TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Added 5 more O-rings to the Kit to cover the entire Cooling System! Now includes O-rings for the Heater Core Hoses and the Expansion Tank Hose.
Complete set of Hi-Temp Silicone and Viton O-rings for the Entire S54 Cooling System. Power Steering and SMG Cap O-ring's also included.
Replace the factory Buna orings with higher quality Hi-temp Silicone and Viton O-rings. These O-rings have higher temperature rating and more resistant to compression set.
1- Temp Sensor- 1
2- Bleeder Screw- 1
3- Exp Tank Return Line- 1
4- Water Pump Lines- 2
5- Exp Tank Cap- 2
6- Exp Tank & Heater Core Hoses- 5
7- Radiator Hose Fittings- 2
8- Water Pump Pipe to Block- 2
9- Power Steering/SMG Caps- 2
10- Water Pump Tstat Housing- 1
Kit includes 2 squeeze tubes of Super Lube and 19 O-rings.
19 O-rings and Lube for $48 Shipped via Priority 3 Day.
Please send funds via PayPal as a gift or add $1.50 to cover the Fee to [email protected]
I have 100% Feedback on eBay so buy with confidence. Wolfn8tr on eBay: https://www.ebay.com/usr/wolfn8tr
Last edited by WOLFN8TR; 02-05-2021, 01:42 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Is Viton unsuitable for colder climates then? In the Great Lakes, it routinely gets into the negative degrees F in the winter. Not that I'd be driving my M3 in those conditions, but unheated garages can definitely dip below 5°F. Can the material rebound from repeatedly cycling down below its low temperature limit, or is it permanently compromised if it has spent time under its limit?Originally posted by WOLFN8TR View PostViton seals hold indefinitely at temperatures up to 400°F and can last up to 48 hours at temperatures up to 600°F. Buna is effective to 250°F. However, it can effectively seal mechanical objects at low temperatures to –22°F. Viton seals are rendered ineffective at temperatures below 5°F, with the material becoming hard and inflexible.
2002 M3 Coupe 6MT
