Bump...🤙
M3 S54 Cooling System Hi-Temp O-ring Kits!
Might as well do it now while my engine is out. Ordered!Last edited by SteelGreyM; 09-03-2020, 09:18 AM.
Originally posted by SteelGreyM View PostMight as well do it now while my engine is out. Ordered!TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
Added 5 more O-rings to the Kit to cover the entire Cooling System! Now includes O-rings for the Heater Core Hoses and the Expansion Tank Hose.
Complete set of Hi-Temp Silicone and Viton O-rings for the Entire S54 Cooling System. Power Steering and SMG Cap O-ring's also included.
Replace the factory Buna orings with higher quality Hi-temp Silicone and Viton O-rings. These O-rings have higher temperature rating and more resistant to compression set.
1- Temp Sensor- 1
2- Bleeder Screw- 1
3- Exp Tank Return Line- 1
4- Water Pump Lines- 2
5- Exp Tank Cap- 2
6- Exp Tank & Heater Core Hoses- 5
7- Radiator Hose Fittings- 2
8- Water Pump Pipe to Block- 2
9- Power Steering/SMG Caps- 2
10- Water Pump Tstat Housing- 1
Kit includes 2 squeeze tubes of Super Lube and 19 O-rings.
19 O-rings and Lube for $48 Shipped via Priority 3 Day.
Please send funds via PayPal as a gift or add $1.50 to cover the Fee to [email protected]
I have 100% Feedback on eBay so buy with confidence. Wolfn8tr on eBay: https://www.ebay.com/usr/wolfn8tr
Last edited by WOLFN8TR; 02-05-2021, 01:42 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Originally posted by WOLFN8TR View PostViton seals hold indefinitely at temperatures up to 400°F and can last up to 48 hours at temperatures up to 600°F. Buna is effective to 250°F. However, it can effectively seal mechanical objects at low temperatures to –22°F. Viton seals are rendered ineffective at temperatures below 5°F, with the material becoming hard and inflexible.
2002 M3 Coupe 6MT
