FS: Porsche 996 Brembo Front/Rear Calipers - BBK Upgrade for E46 M3 - $OLD
    Up for sale is a set of Brembo brake calipers off a Porsche 996. These are commonly used as a brake upgrade on E46 M3s, as a budget friendly BBK solution. There is a wealth of information available regarding this conversion here on this forum in the threads below. In short, in addition to these calipers, adapter brackets, brake lines, ZCP front rotors and some machining work will need to be done to fit these on an E46 M3.
    https://nam3forum.com/forums/forum/m...bbk-conversion
    https://nam3forum.com/forums/forum/m...ersion-install
    Part numbers:
    • Front - 996.351.425 ; 996.351.426
    • Rear - 996.352.421 ; 996.352.422
    The calipers have 70,785 miles and were removed from a wrecked Porsche. Calipers have been cleaned, inspected and tested. All are in good working condition with no frozen pistons, blown seals or torn dust boots. Calipers are as-removed from a Porsche and no work has been done to them. At a minimum, the fronts will need to be machined 5.5 mm and the rear crossover lines will need to be flipped left to right to install these on an E46 M3. I can have this done before I ship the calipers out for a small fee.
    Cosmetically, the paint is faded and bubbling in a few places on the calipers. Most people will want to paint the calipers before install. No major damage to any of the castings. 1 bleeder screw cap is torn.
    Includes a set of nearly new pads, caliper hardware, pad dampeners and pad wear sensors.
    Asking $OLD shipped for the calipers, or $OLD picked up in Columbus, OH.
    Click image for larger version  Name:	20200908_192819.jpg Views:	330 Size:	106.4 KB ID:	54734 Click image for larger version  Name:	20200908_192808.jpg Views:	329 Size:	79.9 KB ID:	54730 Click image for larger version  Name:	20200908_192736.jpg Views:	323 Size:	91.2 KB ID:	54731 Click image for larger version  Name:	20200908_192516.jpg Views:	296 Size:	107.3 KB ID:	54735 Click image for larger version  Name:	20200908_192657.jpg Views:	324 Size:	116.2 KB ID:	54740 Click image for larger version  Name:	20200908_192710.jpg Views:	325 Size:	119.1 KB ID:	54741 Click image for larger version  Name:	20200908_192707.jpg Views:	326 Size:	120.8 KB ID:	54739 Click image for larger version  Name:	20200908_192714.jpg Views:	321 Size:	119.1 KB ID:	54738 Click image for larger version  Name:	20200908_192703.jpg Views:	322 Size:	106.8 KB ID:	54733 Click image for larger version  Name:	20200908_192530.jpg Views:	320 Size:	91.3 KB ID:	54727 Click image for larger version  Name:	20200908_193408.jpg Views:	322 Size:	169.3 KB ID:	54725 Click image for larger version  Name:	20200908_193424.jpg Views:	318 Size:	92.5 KB ID:	54726 Click image for larger version  Name:	20200908_193430.jpg Views:	317 Size:	98.7 KB ID:	54732
    Bump
      Hey. A quick question
      What size spacers and bolts will be needed to mount these brakes.
        Depends on what wheels you have. Stock ZCP is 15 mm w/extended bolts in the front I believe.
          Bump
