ok, another temperature issue
    Gorilla sent me this :thumbs: not looking good for you boys
    my engine done this before i got a new 1 :whistle:
    Most Euro S54 engine's leave the factory with the 88 degree water thermostat, which is useless in warm weather for Track Work on a CSL.
    Anybody who says that running an engine at 125 c oil temp for extended periods is ''OK'' should be forced to pick up all and any engine rebuilds.
    The CSL is compromised in its cooling department.
    Those that say I can do 5/6 laps or whatever on a Track at full this and full that and the temp guage is fine, are either 'crusing around or dreaming'.
    The S54 oil stat opens at around 95/97 degrees, and the only thing that stops it going higher is the std oil cooler.
    Fine if on a Motorway where even at speeds of 120 the engine is not under full load, revs not much more than 5/6000 and the air flow through the oil cooler and the water rad are fine.
    Move onto the Track, now at 97 degrees oil temp and say
    95 degrees water temp, lets do 5 good laps of say Brands or Coombe, engine will be between 60-90% full load for around 80% of the time. Engine rpm window is 6-8000 rpm Air flow through the oil Cooler as compared to a Motorway has dropped by at leat 50% even more if your a slow driver following in another cars turbelent air, and the water temp is now slowly creeping up , why, because as oil temp rises, so will water temp as the water has do effect more cooling due to rising oil temp in the block, ie engine acts as a thermal store.
    10-60 Sythentic oil at prolonged periods, at over 120 c is causing damage.
    For those that do Track Work, at a pure absolute minimum fit the Tropical S54 Thermostat which opens at 55 degrees, and either enlarge the std oil cooling by fitting a piggy back one like Turners sell, pricey, or fit a larger oil cooler than the standard.
    Thus when the oil gets to 97 degrees even at full engine load and only 50 % air flow, the oil cooling will have capacity to keep the oil temp below around 110 and the water with a 55 degree stat will look after itself.
    And before all the Oil experts start shouting that 10-60 Synthetic oil is fine at 120 degrees + its not so much the oil where the damage will escalate from but from seals and gaskets.
      Mine must have stayed cool as no one was in front of me, all of them were behind me:whistle:
      Or
      I was driving like a pussy:whistle:
      But i do know i dont drive like a pussy and my coolant guage did not budge, i know coolant temps will rise slightly but my guage did not move.
      My oil temp did however get to 125c
      Either way i am going to fit a piggy back oil cooler as i dont like the oil getting that hot on track,
      The rise in oil temp does in turn cause the water temp to rise but it will NOT cause the coolant temp to get to near the red if the cooling system is functioning correctly. You will have an underlying coolant issue.
        What will this achieve apart from opening earlier and taking longer to get up to optimum temp? I assume this is the coolant stat you are quoting?
        Once running on track at 97c the stat is already open, whether it be 55c or 88c, so the cooling at this point is the same is it not?
          Hi,
          Lawsy- no disrespect but you have not read the thread
          correctly.
          Oil Stat opens at 97 degrees not water.
          With a 88 degree std S54 water thermostat, your water does not
          just reach temp and stay there, it fluctuates all the
          time, hence why the electric fan cuts in and out.
          So at somewhere like Spa or the Ring, the water temp
          can on parts of those circuits drop below 88 degrees
          and the thermostat shuts. Not good.
          But your oil can still be high, hence by having a 55 degree
          stat in the water system once its open it will never shut
          while on a Track, unless your Ice Racing !!!
          This helps with cooling the Thermal Store.
          Means a couple more minutes in the Pits warming
          up, from cold start, but a small price to pay
          compared to an engine rebuild.
          Hope that explains it.
          Most S54's sent to BMW rated Tropical Areas are sent with the
          55 degree water thermostat for this very reason.
          I sent this mornings reply direct to admin as I could
          not get it to up load due to connection problems at
          this end.
          Regards,
          The Gorilla.
            Originally posted by The Gorilla View Post
            Hi,
            correctly.
            this end.
            Regards,
            The Gorilla.
            No disrespect but i think you have misread my post, and have my car mixed up with another car.
            I neither "cruise" or "dream" My car had its arse kicked all day, albeit not the hottest day, my oil temp was at 125c but my coolant temp never budged all day from halfway.
            My csl does not have an electric fan. But if it did would this not just be to drop the temp down from say 100c?
            Im not doubting what you are saying but you are contradicting yourself slightly,
            "So at somewhere like Spa or the Ring, the water temp
            while on a Track, unless your Ice Racing !!!"
            but your earlier statement says....
            "Move onto the Track, now at 97 degrees oil temp and say
            95 degrees water temp, lets do 5 good laps of say Brands or Coombe, engine will be between 60-90% full load for around 80% of the time. Engine rpm window is 6-8000 rpm Air flow through the oil Cooler as compared to a Motorway has dropped by at leat 50% even more if your a slow driver following in another cars turbelent air, and the water temp is now slowly creeping up , why, because as oil temp rises, so will water temp as the water has do effect more cooling due to rising oil temp in the block, ie engine acts as a thermal store."
            This quote shows you saying the oil getting hot WILL cause the coolant temp to rise significantly. But your later posts says the coolant does drop below 88c even on track.
            I am taking in what you are saying, and i am constantly striving for good input and your posts are both informative and factual, and i agree about the oil temps but the op was talking about his cooling guage showing near the red which in my eyes shows a certain cooling problem,
            Are you saying that the fact that it had a normal stat contributed to his car now getting hot?
            Im genuinely interested in what you are saying, i did understand your first post completely.
            Have you got datalogging from say spa to show this drop in water temp
            How do you know the coolant temps dropped below 88c. What where your oil temps at this point if your oil temps are closely linked with coolant temps?
            I am definitely thinking of running an oil cooler on mine as i was not happy with my oil temps on track.
            So you think we should run the tropical stat? do you have part number for this?
            I am not being funny with my posts i am just trying to gather as much info to keep my engine from exploding as possible, although i do have warranty on mine which i plan on renewing next year.
            Regards
            Lawsy
              I would be interested to hear the views of the UK tuners/racers on this issue.
              But it seems to me that most of us on here frequent the track and i for one am interested in a group buy for the oil coolers and 55 degree tropical stat.
              Who has decent contacts in the trade who could give us a good price?
                Hi,
                Lawsy- I did not think I was contradicting myself,
                I was trying to get across the point that on shorter
                Circuits etc, engine load is usually higher hence the
                oil cooling is insufficiunet and the water temp will creep
                up due to this.
                On more open type Power circuits, engine load can decrease
                slightly but oil temp can remain high
                although the water temp can periodically drop to a point where the std
                water thermostat closes, which is not good.
                Point was, that increasing Oil cooling capacity and ensuring
                that the water thermostat stays open, greatly assists with
                keeping fluid temps in their operating range when using
                the car on Track.
                With regard Data, I have a DL1 in my Car but I have not used in ages.
                Bealo- increasing the size of the oil cooler or fitting a piggy back
                type cooler, is quite straight forward, use the Turner or Vac Oil
                cooler adapter take off kit, and then you can use whatever size
                lines and run them where you want.
                Changing the water stat is a five minute job, but if your car is
                also a road car that see winter use in the UK, keep the std
                stat and put in back in for the winter period, as it will
                help with internal heater / blower.
                Part Number for the 55 degree Water Stat at Turners is-
                11531417215, although I have purchased 2 from the
                local dealer, as it is a BMW part.
                Part number at Turners for the Oil hose take off adapter is-
                TEN9910200. Vac also do this kit.
                I would guess that many of the S54 Race cars run the
                std outer thermostat 'ring' to ensure correct water circulation
                but have removed the stat itself, unless regs state otherwise.
                On my own Car I have converted to an Oil / Water heat
                exchanger and use the air cooled oil cooler as back up.
                You guys with cars with warranties would more than likely have
                them invalidated, so no use to you.
                Hope that helps,
                Regards,
                The Gorilla.
                  Is the cost of the part expensive? What's the complexity of installation?
                    Hi,
                    Ade- 55 Degree water thermostat from the dealer
                    is around the 90.00 ish plus Vat.
                    Installation, is about 15/20 mins Job.
                    Regards,
                    The Gorilla.
                      Hi,
                      Regards,
                      The Gorilla.
                      Thanks :thumbs:
                      My car is at the dealer right now, so I'll ask them to have a look at it whilst there.
                        Hi,
                        up due to this.
                        the car on Track.
                        www.turnermotorsport.com
                        Hope that helps,
                        Regards,
                        The Gorilla.
                        I take on board what you state, you sound like an educated person and i appreciate your experience.
                        I agree with your views on the oil cooler and the stat.
                        I was a little bit worried about my oil temps being so high, esp after coming from my 450bhp tuned evo, which showed about 100c oil temps on track.
                        Thank you for your views and advice, part numbers etc:thumbs:
                          sorry, i'm back from holidays ans a ring trip.
                          it stills overheat even after changing the fan coupling and the stat.
                          I have just noticed the overheating was just after a hard braking. i have tried to stay at full throttle during the overheating (don't panic, i just consider it overheats when the needle is beginning to climb the gauge, but i have never been near the red zone), and the temp just go down to normal temp....if there is a straight line long enough.
                          I have notice the overheating arrived when i was using pagid pads, no problem before with standart pads. I use to lost my front bmw wheel badges on tracks, and when i recovered one, it was jsut burnt !!! any chance to have the braking heat climbing under the hood ????? there is no brake duct in a csl, when i hardly use my car on public roads (:whistle, it never overheats.......when i hardly brake, and after i'm on full throttle, it overheats !!
                          the explaination of "the gorilla" seems good about the stat, why not trying ??
                            There is no way your brakes are making your engine temperature rise.
                              Hi,
                              this part number seems to be a bmw number, could you confirm ?? if not, what is the bmw part number for the 55° stat ?
                                Hi,
                                7.77- I believe the Turner Part number is the
                                BMW Part number.
                                When you order the part just double check that its
                                the ''S50/54 Tropical Thermostat @55 Degrees.
                                Regards,
                                The Gorilla.
