Gorilla sent me this :thumbs: not looking good for you boys
my engine done this before i got a new 1 :whistle:
Most Euro S54 engine's leave the factory with the 88 degree water thermostat, which is useless in warm weather for Track Work on a CSL.
Anybody who says that running an engine at 125 c oil temp for extended periods is ''OK'' should be forced to pick up all and any engine rebuilds.
The CSL is compromised in its cooling department.
Those that say I can do 5/6 laps or whatever on a Track at full this and full that and the temp guage is fine, are either 'crusing around or dreaming'.
The S54 oil stat opens at around 95/97 degrees, and the only thing that stops it going higher is the std oil cooler.
Fine if on a Motorway where even at speeds of 120 the engine is not under full load, revs not much more than 5/6000 and the air flow through the oil cooler and the water rad are fine.
Move onto the Track, now at 97 degrees oil temp and say
95 degrees water temp, lets do 5 good laps of say Brands or Coombe, engine will be between 60-90% full load for around 80% of the time. Engine rpm window is 6-8000 rpm Air flow through the oil Cooler as compared to a Motorway has dropped by at leat 50% even more if your a slow driver following in another cars turbelent air, and the water temp is now slowly creeping up , why, because as oil temp rises, so will water temp as the water has do effect more cooling due to rising oil temp in the block, ie engine acts as a thermal store.
10-60 Sythentic oil at prolonged periods, at over 120 c is causing damage.
For those that do Track Work, at a pure absolute minimum fit the Tropical S54 Thermostat which opens at 55 degrees, and either enlarge the std oil cooling by fitting a piggy back one like Turners sell, pricey, or fit a larger oil cooler than the standard.
Thus when the oil gets to 97 degrees even at full engine load and only 50 % air flow, the oil cooling will have capacity to keep the oil temp below around 110 and the water with a 55 degree stat will look after itself.
And before all the Oil experts start shouting that 10-60 Synthetic oil is fine at 120 degrees + its not so much the oil where the damage will escalate from but from seals and gaskets.
, it never overheats.......when i hardly brake, and after i'm on full throttle, it overheats !!
