Had to happen...
    Originally posted by 97_4dr_5spd_m3
    I usually figure out if it is worth my time and effort in fixing something on my own with each of my cars. For the most part I have done the repairs, but there's been a few instances where I was not 100% sure of the issue and instead of playing that game I left it to the pros.
    My issue is when I decide to hand out over to the "pros" it ends up getting dinged up, or the screw it up worse. Hard to trust anybody top spend the time and have the knowledge to properly diagnose these cars anymore it seems.
      Originally posted by camdinans3
      I don't know much about emissions testing outside new england. I'm just surprised that they test it on a car where they cannot also access an OBD2 port.
      They stopped doing OBD-I testing in MA in 2008. They also decided to stop OBD-II emissions testing for cars older than 15 years on a rolling basis, making all E36s exempt at this point here. Euro motor or S54 swap, here I come.
        Man I'm jelly. Fuk this nazi state
        -tapa
          -tapa
          I mean, I kind of understand CA's rationale on this one. Perhaps not their implementation, but still. http://www.stateoftheair.org/2015/ci...ed-cities.html
            Originally posted by M_Parallel
            Just for the record, but later models don't have this sensor.
            How late? My 98 with a build date of 3/16/98 has the sensor. I had to fix it like the other guy did and it works great now.
              Update...
              The tuning guy called today... He checked the efficency of the cats, and they are dead... Note, I had installed a used OBD2 mid pipe years ago and welded in a percat O2 bung. I was using the simulated narrow band output of the wide band O2 sensor (precat) to feed the ecu. Well, it seems the narrow output is actually 1.2 lower than actual. Meaning that when it was saying 14.7, it was a really 13.5. Running really rich, and that killed the cats.
              So the plan is to install the original obd1 midsection, (glad I'm a pack rat), install a new narrow band O2 sensor to feed the ecu, and check again. If all is good, I'll install a wide band in the exhaust manifold. Then have it all custom dyno tuned....
              Whew...
                Originally posted by Hankdoll
                Mine too. High hydrocarbons. Barely passed (at the limit) last two times.
                Hey Hank, how many miles on your beauty?
                  New update.
                  John, (the tuning guy at At Speed Performance), had a nice chat with Karl at Active about the tuning Karl did for my car. Turns out that Karl used an incorrect scalar for the injectors.
                  So,, here's what they did.
                  Installed original OBD1 midsection. (glad I'm a pack rat). Welded another O2 bung and installed the wideband, and a stock narrowband. Narrow band is now feeding ECU. Corrected tuning,
                  Passed emissions with flying colors.
                  Will finalize tuning on dyno tomorrow.
                  So it wasn't a vacuum leak, it wasn't dirty injectors, or the TPS, or water temp senders, or idle control valve, or any of the other parts I tossed at it...lol
                  It was incorrect tuning that made it run rich, and that killed the cats.
                  I'll let you all know what the final bill comes too.
                    And here you were feeling guilty about taking it to a "stranger."
                    Glad things worked out! Me, I know when I'm in over my head (frequently) and don't hesitate to take it to my man Zack.
                    Glad she's being so well taken care of.
                      Well, I am happy it wasn't anything simple. I already did all that...lol I'm picking it up this afternoon. I'll report back.
