Originally posted by burhan
View Post
DIY: Z3 Non-M gauge cluster to Z3M S54 Conversion
Thank you so much, i will write it and update you soonOriginally posted by JBanzhaf View PostBurhan, I just sent you an EEPROM dump from a US spec E36 M3 cluster. It should match the odometer mileage on your coding plug. So it should not have a tamper dot illuminated. Hopefully this works for you.
Thanks,
Joel
i tried with the dump but it is showing code eep2. also the guage is not working at all. what to do now. appreciate your help.Originally posted by JBanzhaf View PostBurhan, I just sent you an EEPROM dump from a US spec E36 M3 cluster. It should match the odometer mileage on your coding plug. So it should not have a tamper dot illuminated. Hopefully this works for you.
Thanks,
Joel
The EEP-2 fault refers to an issue with the internal EEPROM. It can be either a hardware fault, or an issue with the binary on the chip. In your case, it’s most likely an issue with the binary. Read the dump from the EEPROM again, and verify that it perfectly matches the dump I sent you. Sometimes when you flash these EEPROMs, it doesn’t flash all of the sectors correctly. This will cause this issue. If it still doesn’t work after making 100% sure that it matches the dump I sent you, you’ll probably need a dump off of an identical cluster. In that case, the dump I sent is not compatible.Originally posted by burhan View Post
Hey, I was hoping you could send me the EPROM file for a z3 to z3m conversion, I've just recently swapped a S54 into my Z3 and need to get the gague cluster to have the right range response. I've already read and saved the EPROM file that was stored. If you can help with the coding plug too the mileage that was pulled from the car was 107305 but any help you can give would be great.
Thanks
-Steve
Ijust sent you a DM with the EEPROM dumps you're asking for. If it's going in the original cluster from the car, and the mileage already matches the chassis, you won't need to flash the coding plug. Just in case that's not the case, I also sent you a coding plug dump with your mileage on it. Follow the instructions in the first post. After completed, you'll still have to "sync" to mileage from the coding plug to the internal EEPROM to clear the tamper dot.Originally posted by Steezyz3 View PostHey, I was hoping you could send me the EPROM file for a z3 to z3m conversion, I've just recently swapped a S54 into my Z3 and need to get the gague cluster to have the right range response. I've already read and saved the EPROM file that was stored. If you can help with the coding plug too the mileage that was pulled from the car was 107305 but any help you can give would be great.
Thanks
-Steve
Hello everyone, this is a very interesting topic. I just bought a 2001 S54 Z3 M. Since I couldn't find one in France, I bought it in Canada. I just received it, and to get it approved, I need to modify the lighting, because currently, as soon as the engine is running, the low beams and parking lights (sidelights) work. Canadian standards apply. I've contacted three or four dealerships, and they can't help me. I can't believe it!
I've read several messages talking about coding, but these messages weren't specific to my model. Do you have any ideas? Thanks in advance.
Hi AnthoZ3,Originally posted by AnthoZ3 View PostHello everyone, this is a very interesting topic. I just bought a 2001 S54 Z3 M. Since I couldn't find one in France, I bought it in Canada. I just received it, and to get it approved, I need to modify the lighting, because currently, as soon as the engine is running, the low beams and parking lights (sidelights) work. Canadian standards apply. I've contacted three or four dealerships, and they can't help me. I can't believe it!
I’m really not sure on the specifics of what’s required for you to get it approved. A good start is to see what coding options are available in NCS Expert, for the general module. That should have what you’re looking for.
NCS Expert and NCS Dummy are the programs used for coding E36’s. There are some decent guides online that will teach you how to use them. They are relatively difficult programs to get started with. You’ll also need some type of interface to connect the car to a computer (K+Dcan cable or ICom).Originally posted by AnthoZ3 View PostHi JBanzhaf, Thank you for your message. With what tools (diagnostic case) can I see this?
Hi.
I am new on this forum I am wondering if I can get you support.
As I had a pb with my old odometer of my Z3, so I have bought a New one.
My idea will be to copy dump of my old odometer then to copy on internal eeprom if new odometer, my objective will be to recover my mileage and my vin number.
As I know this internal eeprom is protected so I would like to get your opinion
Thanks
