Are there any limits to number of times you can flash a MSS6x ecu?
MSS6x Flasher - Now released!
This is a sticky topic.
Originally posted by jamam5 View PostHello , first of all thank you for this amazing app, i was able to read full data out of my damaged mss60 . Question , if i write this full data to other dme with same part number will it be full clone of my dme ?
Hi, I see this question has been asked before (but as far as I can find hasn't been answered).
This seems like a great tool! I'm wondering if it's possible to use an ICOM instead of a K+DCAN cable (I have both but my K+DCAN cable is from one stop electronics).
Since normally flashing an ICOM with WinKFP etc. is considered to be safer... I would prefer this option if recommended. Do you have any experience with using an ICOM with your tool? And with your latest update the "Port setting" in the config file should be changed, right?
Originally posted by TNLB7 View PostHi, I see this question has been asked before (but as far as I can find hasn't been answered).
You should be able to leave the port setting alone unless you have multiple FTDI devices connected at the same time.
