MSS6x Flasher - Now released!
  • Martyn
    Ensure the path is correct under 'ecuPath' and you can try setting "port" to COM1 in MSS6x Flasher.exe.config
    Also ensure Ediabaslib is in the same folder as MSS6x Flasher.
  • ppm008
    Yes, INPA; Toolset and Winkfpt are working like a charme.
    So I only have to start mss6xflasher.exe, nothing else to do ?
    MSS65 uses KCAN and not DCAN.
    Ediabas cable is on COM1, although in OBD.ini.
    ediabas.ini ist on STD:OBD
    But I read in MSS6x Flasher.exe.config:
    ="Port" value="FTDI0"
    I guess FTDI0 is USB to Serial
  • Tomba
    Originally posted by ppm008 View Post
    Thanx
    But no chance
    So INPA works but the flasher doesn't?
  • ppm008
    Thanx
    But no chance
  • Tomba
    I tested reading MSS65 (2005) and use a BMW USB Ediabas cable.
    But i get always ECU "unknown/unsupported"
    May i switch in config file the port=FTDI0 to something else ?
    Try to read it first with INPA or Tool32 and then run the Flasher. Sometimes this helps.
  • ppm008
  • binary420
    Originally posted by Dash1 View Post
    Hi everyone,
    Was wondering if anyone has ever encountered this before?
    Click image for larger version  Name:	image.png Views:	36 Size:	71.5 KB ID:	194961
    The flasher gets stuck at "Reading RAM @ 0x400000" perpetually while reading a full flash. So far it has happened three out of four times. First time was on my 2011 E92, tried it a second time and it worked as advertised. Third time was on a friend's 2008 E90, got stuck as seen in the figure. Tried it a fourth time with the same result. Any leads or help would be appreciated!
    FYI, I'm using a bimmergeeks cable, confirmed all device settings were correct (com1, 1 ms latency, etc.)​
    even while your latency and com port are correctly configured,
    the complete configuration of the kdcan cable driver may not be complete
    change the file extension of the attached .txt file to a .exe and copy it into c:\ediabas\hardware\obd\
    if that folder doesnt exist, create it.
    run the program, and it will pop up a cmd with roughly 10 diferent settings.
    if they are all properly configured, they will say: value xxx expected xxx "OK"
    if the expected and actual values are not the same, you'll need to edit those settings in your registry (regedit)
    the location in the registry is SYSTEM\CurrentControlSet\Services\Serial
    you may have to add some of the settings if they arent already listed, or change the settings that dont match the cmd window.
    once changed, re-run the program till all the settings say "OK"
    attached are screenshots of the cmd and registry with all the correct values.
Name:	regedit screenshot.png
ID:	197554 Click image for larger version
Name:	obdsetup screenshot.png
  • Dash1
    Hi everyone,
  • binary420
    Originally posted by MpowerE36 View Post
    Yes you can buy a KTag or FGTech v54 to try flashing your backup but if your injection processor is bdm locked, you won't be able to recover it. You need a special debugger tool to unlock the bdm access of this processor. If you want more information about it you can read the "MSS60 Research" topic from Terra.
    Thanks for the reference to that thread.
    helpful
    couple quick questions.
    I have been searching for a set which has a DME, CAS, and key already matching to make things easier.
    Will that in fact make things easier or am i wasting my time since ill have to program them anyway if i want my original vin programmed?
    Because ive found a few of these prematched sets, but none that have a perfect match to my dme/cas3 part #s.
    also, how important is it to have a part number (both for dme and cas) that match the original exactly.
    Realoem shows that mss60 are retrospectively interchangeable, and dct / manual doesn't matter.
    But every ebay listing is very strongly stating to make sure to match part numbers exactly.
    and some are listed as manual only, and some DCT only..
    I get it on their end, so people arent buying the wrong shit and returning
    but just want to be clear about that from actual knowledgeable people,
    Do the part numbers need to be identical for any reason? Or as long as it shows on realoem as interchangeable, It can be cloned to without issue?
  • isma_s54
    hello guys the program work good read all flashes good but when i load full flash i cant baypass rsa
    mss60
    the program load only tune
  • MpowerE36
  • binary420
    So based on what I've found online, it seems my only options are to either buy some device to possibly be able to bdm flash the backup to the ecu,
    or otherwise to buy a replacement mss60 ecu.
    And if I want it to work with my car, I'd either need to immo off flash the new dme,
    or buy a matching dme/cas/key set
    Is there no other solution to recover the dme with say nfs emergency flash or something?
  • binary420
    One thing that wasn't made clear to me in the directions is:
    Once rsa bypass is added, is it permanently bypassed?
    Or can it be relocked again?
    the instructions say add the bypass first time, then flashes can be performed at will,
    But wasn't clear what exactly that meant
    My non-coder self was left scratching my head on what that means.
    But now I'd very much love to just get it fixed
    Especially now after it got bricked
  • binary420
    So yes your dme is bricked. The only way to recover it is to write a full binary via bdm. Do you know if your injection processor is bdm locked ?
    I tried reading it with tool32 ident, and winkfp, and scan tool but nothing could read it.
    Then I tried for shits and giggles with an older program in bmwkiller software package, and it showed something in German saying "~~german~~blocked" so that might be what yr referring to.
    I have a x431 scanner and an xprog3 programmer can this be performed with that or I gotta order a different programmer
    And then is there any guide / walk through for performing this unlock
    In other words no I don't know if its locked.
    I had flashed the rsa bypass previously though so unless winkfp added it back then should b unlocked
  • MpowerE36
    Originally posted by binary420 View Post
    Sadly no
