Originally posted by MpowerE36
MSS60 OBD locked
Here your original fullbinary. You just have to load the file in MSS6xflasher, then clic on "Flash Program". You must have a good cable (with ediabas lib firmware) to write in your ecu. After that, you will be able to read it. I recommand to do a full backup of your ecu.Attached FilesLast edited by MpowerE36; 08-19-2025, 02:21 PM.
Confirming:Originally posted by MpowerE36 View PostHere your original fullbinary. You just have to load the file in MSS6xflasher, then clic on "Flash Program". You must have a good cable (with ediabas lib firmware) to write in your ecu. After that, you will be able to read it. I recommand to do a full backup of your ecu.
1. I download the bin file you provided.
2. Load file, and select the full dump (5120KB) you provided.
3. Click Advanced and pick one of the RSA bypass options or click on "Flash Program"?
Do I need to read the ISN/secret key in advance?
Thanks
1) Load File
2) Flash Program
That's all.
You will not be able to read your SK untill you unlock your dme.Last edited by MpowerE36; 08-29-2025, 02:37 PM.
The issue I'm currently facing is that when reading all DME data, the program runs normally but gets stuck reading the data and stops executing further. The longest I've waited was two hours, yet it remained frozen on a single value. Could you help me analyze what the problem might be?Originally posted by MpowerE36 View PostSorry but I don't know this type of dcan cable.
