MSS60 XDF Mappings
    Originally posted by hotsd101 View Post
    Can somebody reupload A2L pack? I want to tune Schrick 292 cams.
      This might be useful
        Hello,
        Thats my first post so greetings from Germany
        Just a quick question. What Parameters do I have to Change to get very Slight Pop and Bangs or more of a crackle in only m Mode?
        I have enough knowledge with win ols. Just asking for a small manual or a list.
          Originally posted by Acevin1 View Post
          Hello,
          some negative timing in decel areas. What are you using to upload files?
            Question on the wilhelmina xdf on the github. Does anyone have the static injector flow table (and axes) addresses?
            Also, is there an offset that can be applied to the .xdf to work with the tune file rather than the full flash? I'm working with the full flash and it's cumbersome....
            And one more thing on that xdf, it appears that the cat warming and standard vanos maps are labeled backwards. I double checked this by flashing and watching INPA data, so please check me on this!!!
              Hi, I got no car to test, so would you mind sharing your INPA screenshot and the VANOS table you edited? I'll update the xdf. And I do have a partial xdf if you need it.
                Originally posted by omhl View Post
                Hey everyone,
                I'm trying to create an XDF to share with the forum with the binaries that we are reading from the MSS6X Flasher.
                Just sharing some of my identifying findings using the MSS6X Flasher so far. Hopefully we can identify some more mappings! I am looking for servotronic comfort/sport addresses. pedal throttle map comfort/sport, ignition min(KF TZ VL MIN), WOT Fueling. I won't bother with cold start, o2 dtc stuff since ECUWORX tool can handle that.
                Please share if you have any!
                This is from 241E read.
                RPM Limiter:
                0x6062
                1x8
                16 bit
                Columns: 0x6052
                values:
                8000 8300 8300 8300 8300 8300 8300 8300
                TEMP RPM
                0x6088
                6x1
                columns: 0x6088
                row conversion: (X*0.1)-273.2 to degrees
                -25.0 0.0 25.0 50.0 60.0 80.0
                5000.0 6000.0 6500.0 7000.0 7500.0 8300.
                Vanos Admission:
                0xA862
                16x12 table
                16 bit
                Row: 0xA82A
                Column: 0xA84A
                Conversion: X/10
                stock values:
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 112.0 103.5 97.7
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 105.0 100.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 103.9 98.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 101.1 95.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 118.0 97.0 87.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.7 114.0 87.0
                131.0 130.9 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 116.0 83.0
                131.0 131.0 131.0 130.0 127.0 126.0 124.0 124.0 128.1 124.0 115.7 83.0
                131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 115.7 83.0
                131.0 131.0 131.0 131.0 130.0 130.0 130.0 130.0 126.6 122.8 114.9 92.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 130.0 124.4 118.1 112.4 93.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 129.0 118.6 114.2 109.3 99.8
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 112.8 111.6 107.9 104.0
                131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 108.2
                131.0 131.0 131.0 131.0 131.0 131.0 122.0 102.0 94.1 96.0 101.5 112.0
                131.0 131.0 131.0 131.0 131.0 131.0 121.9 100.1 92.2 95.8 103.5 120.0
                Vanos Admission Heating (KATH):
                0xABD6
                16x12
                16 bit
                Row: 0xAB9E
                Column: 0xABBE
                Conversion: X/10
                stock values:
                131.0 131.0 131.0 131.0 131.0 131.0 131.0 126.8 123.0 109.0 98.5 97.7
                131.0 131.0 131.0 131.0 131.0 130.9 129.3 124.0 119.0 110.7 100.0 100.0
                131.0 131.0 129.0 125.6 123.0 120.3 117.0 119.0 119.0 116.7 98.9 98.0
                131.0 131.0 127.3 120.5 117.1 115.8 114.4 117.2 124.8 117.0 95.5 95.0
                131.0 131.0 127.3 120.4 117.0 116.0 115.0 117.3 125.7 117.0 91.0 77.0
                131.0 131.2 127.0 120.0 118.0 116.0 115.0 117.0 125.0 123.7 106.0 77.0
                131.0 130.9 129.1 124.0 118.0 116.5 116.6 119.1 127.0 123.6 111.0 77.0
                131.0 131.3 129.7 125.0 118.0 117.0 117.6 120.6 128.1 124.0 110.7 75.0
                131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 110.7 78.0
                131.0 131.0 131.0 131.0 130.5 130.0 130.0 130.0 126.6 122.8 114.9 87.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.3 130.0 124.4 118.1 112.4 93.0
                131.0 131.0 131.0 131.0 131.0 131.0 131.9 129.0 118.6 114.2 109.3 99.8
                131.0 131.0 131.0 131.0 131.0 131.0 131.3 123.6 112.8 111.6 107.9 105.0
                131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 110.0
                WOT Ignition Timing KF_TZ_VL
                0x28E1EC
                16x3
                Row: 0x28E1C2
                Column: 0x28E1E6
                Conversion: x/10
                stock values:
                3.0 3.0 3.0
                16.0 16.0 16.0
                20.0 20.0 20.0
                27.0 27.0 27.0
                30.0 30.0 30.0
                30.0 30.0 30.0
                34.0 34.0 34.0
                33.0 33.0 33.0
                33.0 33.0 33.0
                31.0 31.0 31.0
                33.0 33.0 33.0
                33.0 33.0 33.0
                30.0 30.0 30.0
                30.0 30.0 30.0
                30.0 30.0 30.0
                31.0 31.0 31.0
                32.0 32.0 32.0
                32.0 32.0 32.0
                Limp Mode Pedal
                0x28ACC6
                10x1
                Column: 0x28ACB2
                Conversion: x/10
                00 08 16 25 30 35 40 43 46 50
                Nice work on the mappings. The VANOS admission table at 0xA862 and the heating table at 0xABD6 line up well with what I’d expect from the MSS60 structure, and the X/10 scaling checks out against the stock values.
                One thing I’d be careful about before publishing the XDF is validating the addresses against multiple 241E reads rather than assuming every MSS60 binary will have identical offsets. It would also be useful to document the axis addresses and data types explicitly in the XDF so people don’t accidentally interpret the tables incorrectly.
                For the remaining maps, I’d be particularly interested in the Servotronic comfort/sport maps and the pedal/throttle maps. The WOT ignition KF_TZ_VL mapping at 0x28E1EC is also a good find.
                If anyone has a known-good modified 241E binary, comparing the changed regions against stock should make identifying the remaining maps much easier.
