My friend recently purchased an E46 M3 which has a strange ticking/rattle noise emanating from the motor. It's no secret that the S54 is a noisy motor but is this sound anything to worry about or is it just normal. The car recently had the rod bearings replaced, valve shims checked, and Beisan chain guide and oil pump disk installed.
Weird S54 Rattle/Tick Noise
Journal: https://nam3forum.com/forums/forum/m...grey-speed-runTags: None
The higher frequency "click" sounds like a good ol S54 to me. As you said, these engines are noisy.
The lower frequency "thump" is not normal. Maybe a heat shield or plastic piece rattling somewhere? Hard to tell with a short video clip.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Sheared VANOS bolts? I don't know - sounds a lot like this car => https://www.zpost.com/forums/showthread.php?t=1808145
sounds just like what xmetal posted. relatively 'lucky'2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Originally posted by Xmetal View PostSheared VANOS bolts? I don't know - sounds a lot like this car => https://www.zpost.com/forums/showthread.php?t=1808145
So far done within the last 8,000 miles:
- BMW's updated VANOS cam bolts (4 out of 6 bolts were split in half)
- Beisan VANOS oil pump disk (had some wear)
- Beisan entire sealing kit
- Beisan timing chain guide (was split in half)
- Rod bearings (lots of copper)
- Valve adjustment (90% of the valves were out of spec)
- Engine mounts
- Guibo/flex disc
- Center driver shaft support
- Every drop of fluid replaced
The car sits at 108,000 miles and pulls very healthy and once the oil reaches to the operating temperature the sound goes away. But I know that this is not one of those usual S54 symphonies. It just doesn't sound right.
Originally posted by Xmetal View PostSheared VANOS bolts? I don't know - sounds a lot like this car => https://www.zpost.com/forums/showthread.php?t=18081452003.5 E46 M3 Silver Grey/Cinnamon
Could be an oiling issue because of the oil disk. There was a thread on using another oil disk from a different Vanos. The pistons in the oil disk could sticking. That was another mention in the thread. Was the vanos filter replaced?This is my Unbuild Journal and why we need an oil thread
Just wanted to give an update in case anyone comes across a rare occurrence as this one.
As noted above, the VANOS was rebuilt with the genuine BMW updated cam bolts, Beisan oil pump disk, viton rings etc. We went in again, this time to install the 272/280 cams that I bought on betr a while ago and realized the intake side cam bolts that we had just replaced 12K miles ago have failed again. So with all the honesty, we would have never thought of inspecting the cam bolts if it wasn’t for the cam upgrade. Not sure if this was an install error on our end or something got damaged when the original 4 out of 6 intake side cam bolts failed. But this time we installed Lang Racing cam bolts with super care.
Either way, the rattle is gone and the motor sounds super happy. Will be on the dyno for a live tune in hopefully a few weeks.
By failed you mean sheared?
Thanks for providing an update for future users to reference even though you weren't the original poster.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Weird. What torque these bolts were tighten to, and if Loctite was used on the cleaned cam threaded holes?
