Originally posted by SteelGreyM
Caliper bleed screw broken off...
Sorry to hear the bad news, but what was your plan of drilling it? The drill could easily off center and damage the female threads. $10 impact driver is the way to go.
So basically at this point I need to have my machine shop drill it out super clean and extract.
If they can’t get it done then I’ll need a new (used) caliper. Which I will probably rebuild along with the other ones on the car.
And yes, I purchased 4 new bleeder valve/screws. Going to replace all those stupid things
Originally posted by Slideways View PostNot sure what a machine shops charges, but a used calipers is probably 30 to 40 bucks.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by SteelGreyM View PostBad news... drill bit broke off and got hopelessly stuck inside. After a few hours of frustration I have given up. Ill be contacting my machine shop guys and pray that they will drill it out for me there.
Originally posted by SteelGreyM View PostBad news... drill bit broke off and got hopelessly stuck inside. After a few hours of frustration I have given up. Ill be contacting my machine shop guys and pray that they will drill it out for me there. if not... anyone selling a CSL/ZCP right rear caliper?
Any updates on if the shop was able to fix it or did you get a used caliper?
Originally posted by JokerElite View Post
The exact same thing just happened to me today. It seems surprisingly common, I think bleeder screw replacement should be part of 10 year/100k maintenance.
SteelGreyM Where are you located? If you're somewhat close by or want to ship the caliper, assuming you didn't completely ravage it with a drill bit, I could try to extract the bleeder for you. I have the tooling and experience.
