What Else Should I Change When I do My Clutch?
On metal pin, IF you are going with metal, def don't do brass, do steel.
Flywheel is just a waste of money, if your current clutch hasn’t been slipping. The original fly wheel is good for 2-3 clutches, so long as it hasn’t been scored.
I wouldn’t do detent springs, either— they don’t seem to go bad like on other cars.
Metal pivot pins add nhv. If that’s worth it is up to you. Personally I’d replace with new plastic— failure is pretty rare. If you do go with a metal one, I’d use the OE BMW metal one.
I’d do:
new plastic pivot pin
new OE throw out bearing
new pilot bearing
rear main seal
clutch/pressure plate
guibo
center support bearing
any exhaust nuts removed
any exhaust gasket removed
IF your trans is leaking, replace seals that are leaking. Our trans seems to be pretty leak resistant, so I’d skip replacing it if not.
I remember getting confused a few months ago as I found a thread or two in the old forum proclaiming/showing that metal pins do also deform in a worse way and that the original nylon's the way to go. Never followed up to try figure out what was what, and now all those posts are gone.
Feff
Are you talking about part number 23117512866? Damn that's an expensive part lol. Will also be getting an AutoSolutions SSK. Very excited about that.
Originally posted by HDdave View PostMaybe the guibo? Otherwise it seems like you have got the list covered pretty well. You may want to consider replacing your dual mass flywheel.. I did my conversion at 151k and went ahead and did the flywheel. The new one did have a substantial amount less play.. I don’t think I would mess with the other seals unless necessary though.
Originally posted by mrgizmo04 View PostOutside of getting a new fork, make sure to also get the sleeve/guide that goes over the tranny input shaft, it also gets gouges.
Without the bellhousing there you have a bit more access to cpv. Might be worth to replace the flywheel, even of the surface might look ok, there could be some play from dual masses. Your driveshaft will be partially out, so you can do guibo/csb, tranny mounts. Front tranny seal is not bad at all, rear is a bit more work due to the big nut. Outside of getting a new fork, make sure to also get the sleeve/guide that goes over the tranny input shaft, it also gets gouges. Do all detents with springs and guides, there should be about 7. I got a metal pivot pin, seemed to make more sense to have metal on metal with fork vs plastic. All the bushings in shifter will tighten everything up very nicely. You could also get a different shifter now. Rear main - be VERY careful with, you don't want to do it again, definitely use the plastic inner cup it comes with. Chance to replace starter if you want, slave cylinder, etc.
Right. Planning on replacing the pivot pin and release arm as well. What's the consensus on metal pins? I'm a bit wary to use one as it won't deform and might damage other parts in situations where a plastic one wouldn't.
Originally posted by rbg View PostMake sure you replace that fork pivot pin and maybe use a metal one.
I'm getting ready change out the clutch in my car. Plan on replacing it with the Luk kit and using OE throw out and pilot bearings. Since the trans will be out of the car, I plan on replacing all detent springs, rear main seal, driveshaft centering sleeve, and shifter bushings.
I was thinking of doing the seals for the input, output, and selector shafts, but my recent experience installing a new front crankshaft seal is making me want to stay away from radial seals. My trans has no leaks and so it seems replacing these seals isn't necessary. My car has 122k on it so should I replace them anyway?
Is there anything else I should do with the trans off? Thanks!
Edit: This is the list of things I ended up ordering for myself. I left a couple of things out (some shifter bushings, exhaust gaskets, etc) because I either already had them or they were included as part of the aftermarket pieces I bought.
Item Part Number Quantity Unit Price Total Price Vendor Luk Clutch Kit - 1 $269.29 $269.29 Amazon Pressure Plate Screws 21207548052 6 $1.52 $9.12 FCP Throw Out Bearing Guide Tube 23117512866 1 $65.78 $65.78 ECS Throw Out Bearing 21511223582 1 $73.77 $73.77 FCP Pilot Bearing 11211720310 1 $26.40 $26.40 FCP Steel Pivot Pin 21511223281 1 $23.92 $23.92 FCP Release Arm 21511223302 1 $30.72 $30.72 FCP Locking Pin 23111222979 1 $20.05 $20.05 ECS Locking Pin 23311224130 1 $17.06 $17.06 ECS Ball 7119986280 1 $0.99 $0.99 ECS Locking Pin 23317501584 1 $39.29 $39.29 ECS Thrust Pin 23311282444 1 $27.16 $27.16 ECS Compression Spring 23311228393 1 $7.04 $7.04 FCP Compression Spring 23111222720 1 $8.77 $8.77 FCP Compression Spring 23317511337 1 $9.55 $9.55 FCP Compression Spring 23311228405 1 $9.32 $9.32 FCP Repair Kit 23317506947 1 $186.24 $186.24 ECS Flywheel 21212229900 1 $383.34 $383.34 FCP Flywheel Bolts 11222243051 8 $2.39 $19.12 FCP Rear Main Seal 11142247867 1 $122.45 $122.45 FCP Input Shaft Seal 23121228493 1 $14.43 $14.43 FCP Output Shaft Seal 23121222769 1 $5.32 $5.32 FCP Shift Selector Seal 23127501582 1 $22.12 $22.12 FCP Driveshaft Centering Sleeve 26117526611 1 $9.25 $9.25 FCP Guibo 26112226527 1 $68.78 $68.78 FCP Guibo Nuts 26127536563 6 $1.63 $9.78 FCP Exhaust Gasket 11627830668 2 $14.43 $28.86 FCP Exhaust Nut 18301317898 4 $6.35 $25.40 FCP Exhaust Nut 11621744323 6 $3.07 $18.42 FCP Shifter Arm Bushing 25111222015 1 $18.61 $18.61 FCP Autosolutions AutoCross - 1 $540.00 $540.00 AutoSolutions Last edited by heinzboehmer; 04-17-2020, 05:21 PM.Tags: None
