I'm getting ready change out the clutch in my car. Plan on replacing it with the Luk kit and using OE throw out and pilot bearings. Since the trans will be out of the car, I plan on replacing all detent springs, rear main seal, driveshaft centering sleeve, and shifter bushings.
I was thinking of doing the seals for the input, output, and selector shafts, but my recent experience installing a new front crankshaft seal is making me want to stay away from radial seals. My trans has no leaks and so it seems replacing these seals isn't necessary. My car has 122k on it so should I replace them anyway?
Is there anything else I should do with the trans off? Thanks!
Edit: This is the list of things I ended up ordering for myself. I left a couple of things out (some shifter bushings, exhaust gaskets, etc) because I either already had them or they were included as part of the aftermarket pieces I bought.
Item | Part Number | Quantity | Unit Price | Total Price | Vendor |
Luk Clutch Kit | - | 1 | $269.29 | $269.29 | Amazon |
Pressure Plate Screws | 21207548052 | 6 | $1.52 | $9.12 | FCP |
Throw Out Bearing Guide Tube | 23117512866 | 1 | $65.78 | $65.78 | ECS |
Throw Out Bearing | 21511223582 | 1 | $73.77 | $73.77 | FCP |
Pilot Bearing | 11211720310 | 1 | $26.40 | $26.40 | FCP |
Steel Pivot Pin | 21511223281 | 1 | $23.92 | $23.92 | FCP |
Release Arm | 21511223302 | 1 | $30.72 | $30.72 | FCP |
Locking Pin | 23111222979 | 1 | $20.05 | $20.05 | ECS |
Locking Pin | 23311224130 | 1 | $17.06 | $17.06 | ECS |
Ball | 7119986280 | 1 | $0.99 | $0.99 | ECS |
Locking Pin | 23317501584 | 1 | $39.29 | $39.29 | ECS |
Thrust Pin | 23311282444 | 1 | $27.16 | $27.16 | ECS |
Compression Spring | 23311228393 | 1 | $7.04 | $7.04 | FCP |
Compression Spring | 23111222720 | 1 | $8.77 | $8.77 | FCP |
Compression Spring | 23317511337 | 1 | $9.55 | $9.55 | FCP |
Compression Spring | 23311228405 | 1 | $9.32 | $9.32 | FCP |
Repair Kit | 23317506947 | 1 | $186.24 | $186.24 | ECS |
Flywheel | 21212229900 | 1 | $383.34 | $383.34 | FCP |
Flywheel Bolts | 11222243051 | 8 | $2.39 | $19.12 | FCP |
Rear Main Seal | 11142247867 | 1 | $122.45 | $122.45 | FCP |
Input Shaft Seal | 23121228493 | 1 | $14.43 | $14.43 | FCP |
Output Shaft Seal | 23121222769 | 1 | $5.32 | $5.32 | FCP |
Shift Selector Seal | 23127501582 | 1 | $22.12 | $22.12 | FCP |
Driveshaft Centering Sleeve | 26117526611 | 1 | $9.25 | $9.25 | FCP |
Guibo | 26112226527 | 1 | $68.78 | $68.78 | FCP |
Guibo Nuts | 26127536563 | 6 | $1.63 | $9.78 | FCP |
Exhaust Gasket | 11627830668 | 2 | $14.43 | $28.86 | FCP |
Exhaust Nut | 18301317898 | 4 | $6.35 | $25.40 | FCP |
Exhaust Nut | 11621744323 | 6 | $3.07 | $18.42 | FCP |
Shifter Arm Bushing | 25111222015 | 1 | $18.61 | $18.61 | FCP |
Autosolutions AutoCross | - | 1 | $540.00 | $540.00 | AutoSolutions |
