225/255 vs 235/265 split... Your pick and why?
    Originally posted by joshuatrueanderson View Post
    Perfect timing for this thread. My wheels arrived today and havent pulled trigged on tires due to not knowing correct sizing going from 19" OEM to 18" aftermarket
    I bought Enkei NT03+M
    18x8.5 in front
    18x10 in rear
    Looking at Michelin Pilot Sport 4S for this.
    Sounds like Ill be going the 245/275 route.
    You know what would be interesting is if you ran a 245/40 and 285/35. The circumference is the same difference as a 245/275 except the 285 is larger (meaning less likely to trigger the DSC). The reason for this would be to get the exact same tire stretch in front and rear. With a 245 on an 8.5" rim the tire face goes up vertically, and with a 275 on a 10" rim the tire face has a slight inward angle.
    So I would consider a 245/285. Anyone see a reason to not do this?
      Heck I would go 245/275. I love mine, and running them on 18x8.5 fronts and 18x10 rears. They look perfect, not stretched or bulging. Big handling upgrade over the stock 225/255 as well.
      This doesn't help op but 245/275 is my favorite combo and is a massive difference. When I had to run stock rims/sizes afterwards once the car felt like it was on ice by comparison then again no real surprise there.
      I'd do at least the plus size route 235/265 if I were you.
        245/275 is great.
          Second this! Absolutely ZERO reason to run stock again. 235/265 work great on stock 19's. Question for this group will 245 fit on stock 19" wheels at 8" wide?
          maw
            Most 245 tires are going to be too wide for an 8-inch wheel, those would be better suited for 8.5s or 9s.
            '01 M3, Imola/black
              Originally posted by bjz! View Post
              245/275 is great.
              dumb question but what what side wall size (ratio) should I go with with PS4's on 18 inch wheels, 35 or 40? Discount tire direct is having a great sale right now and was quoted $760 for (2) 245/35/18 and (2) 275/35/18...
              But then I didnt know if this was too low of profile or if I should go with 40?
              Any input?
                The tire thread sticky recommends 245/40-18 and 275/35-18
                  A 245/35-18 is almost an inch shorter than 275/35-18
                    Any input?
                    245/40 for the front and 275/35 rear
                      I am debating on the exact same EC7 staggered setup for 235/245 F and 265/275 R
                      18x8.5 ET35 for front
                      18x9.5 ET22 for rear
                      I made a comparison with OEMs to check the wheel diameter. I found Euro CSL overall diameter is slightly smaller (641 mm) in comparison to north america competition ZCP (661mm).
                      235/40/18 & 265/35/18 will have smaller overall diameter, which means it has closer look to European CSL, but also giving about additional 10mm drop due to smaller radius [ (662mm-641mm) /2]
                      245/40/18 & 275/35/18 is somewhat between euro CSL and North America M3
                      I am more leaning towards the wider combination, but I have stock suspension with H&R sport springs (F -1.2" ; R -0.5"), so I wasn't sure if 245 / 275 combo will rub with my stock camber setting.
                      OEM CSL OEM ZCP 19" OEM 18" OEM EC7 18x8.5 EC7 18x9.5 EC7 18x8.5 EC7 18x9.5
                      F R F R F R F R F R F R
                      Tire Width 235 265 225 255 225 255 225 255 235 265 245 275
                      Ratio 35 30 40 35 40 35 45 40 40 35 40 35
                      Wheel Size 19 19 19 19 19 19 18 18 18 18 18 18
                      tire OD 647.1 641.6 662.6 661.1 662.6 661.1 659.7 661.2 645.2 642.7 653.2 649.7
                      Offset 47 27 47 27 47 27 47 26 35 22 35 22
                      Wheel Width 8.5 9.5 8 9.5 8 9.5 8 9.5 8.5 9.5 8.5 9.5
                        I like to have as much sidewall as possible, so not really a fan of 235/265
                          Any downsides running 245/265 as e92 has from factory? May it be a tad more neutral than 245/275?
                            Might trigger DSC and be more intrusive. More of a stretched look on 9.5"+ wheels. Slight less comfy maybe.
                            I used to be a proponent of 235/265 as it's a little faster (mechanical leverage) and lighter, but was glad to be back on 245/275 recently. I like the meatier look a lot more too.
                              If you drive with DSC on, you won’t like it.
                                Got rid of those mega heavy ZCP/CSL wheels for some ARC8? Such a massive difference.
                                Instagram: @logicalconclusion
