Diff ring gear bolts removed without using big vise?
    I thought we had discussed this before, but I couldn't find the thread and so this new thread is created.
    Looking at the pic, I think using a boxed wrench we could loosen the bolts while the diff still on the car, by pulling the handbrake hard to lock the drive shafts. Not everyone has a big vise bolted down on a sturdy work bench to hold the round carrier.
    But this housing is slightly different, and the box wrench might not clear the wall:
      Pull it out from casing and use an impact wrench.
        Then why the pros at Racing Diff used a big vise and a long breaker bar to loosen the bolts, then he used the power tool to get them out?
          why don't you ask the "pro"?
            I believe impact wrench can weaken the bolts. It generated very high impulse torque, like hammering. If you don't reuse the bolts then impact tool is fine, but I won't use the tool if I want to reuse the bolts.
              Why would you go through all that to reuse the ring gear bolts?
              ​​​​​​they are cheap enough to replace.
                Any reason not to reuse them? Don't like to trash good stuffs. Where do you get them new as I don't see them on RealOEM?
                  As tight as some of those bolts were, I’d hate to loosen them in the car with a wrench. It took some serious torque to break a few of them loose. I bought a vise from the hardware store and installed it on a makeshift table. Then used my foot to keep it from moving when I broke them loose. I didn’t want to install the vise on my nice workbench but It’s been pretty handy several times since then.
                    Yes, these bolts were torqued to around 110 ft-lbs (based on Racing Diff video), but the hand brake -- drive shaft -- output flange -- side gear -- spiders -- carrier should be able to handle this easily as we all know the system is capable of burning the tires.
                      I was looking at the E46 M3 Torque Spec in the Tech Section but couldn't find the ring gear bolts torque spec. But I found this pic. interesting: in the back ground is a Porsche 901 dog-leg transaxle that I'm very familiar with -- I have a few spare and had converted one from 4 speed to 5-speeed, and changed a few gears to suite my FWY commuting. Is this from TIS or from a member here?
                        Rather than roughly clamping the LSD unit in a vice, i welded up a specific jig for this job so the bolts can be correctly removed and torqued. I wouldn't recommend an impact gun if re-using the bolts as mentioned.
                          From what I could find the bolts are M14s and the torque is either 162 ftlbs or 177 ftlbs. I think non M bolts are different but I have not had a BMW diff apart yet to confirm. I'm still searching but this is somewhere to start.
                            Excellent idea, but why not just have a plate with 3 holes: the big center hole to clear the side-gear boss, and two outer holes to clear the bolts? This plate alone is much stronger than having the 2 "prong" bolted to the plate working as the stoppers.
                              I'm sure that would work as well, however, a flat plate wouldn't have too much material in the center area if the carrier bearing is still in place so may be a little weak - with this design I can bolt down the bar assembly and the two location sockets and it holds everything solid with no issues removing or applying torque to the bolts
