Originally posted by yhp2009
View Post
Feeler: Interest in Bilstein Coilovers GB
^^Yes to that.Originally posted by T.J. View Post
For what it’s worth my experience is almost opposite. I run pss10 on full soft and find it comparable to stock if not a hair less harsh. The best thing I can say about the kit is that it is incredibly settled. Hit a bump on the freeway and it’s one motion then settled. I did turn up the damping once and turned it right back down after being jiggled over a smooth road.
Also, how coilovers "feel" will also be dependant on the alignment. Often times shops will add camber and negative toe on lowered cars as they assume high performance driving. It will feel very different than stock and highway driving will feel hectic with an alignment change.
I'm not a huge fan of the Ohlins R&T due to their rebuild intervals - but I can see the value. It's a very high quality bit of kit. I haven't reached out to them. If you guys have interest, I can try!
+1 for OhlinsOriginally posted by Epoustouflant View Post
^^Yes to that.
I'd be very interested if Ohlins R&T were added as an option. Specifically the preassembled kits that 3dmmotorsport sells that include camber plate options and front strut spacers. Maybe you could try reaching out to them and see if they'd be interested in supported a group buy?
Not a huge PSS10 fan due to the amount of work/cost associated to convert to linear springs. But they are a great street option imo.
Great job organizing these btw.
Thanks a bunch for the support.Originally posted by BottleRocket View PostI'd be very interested if Ohlins R&T were added as an option. Specifically the preassembled kits that 3dmmotorsport sells that include camber plate options and front strut spacers. Maybe you could try reaching out to them and see if they'd be interested in supported a group buy?
I'll give it a shot specifically for E46 guys. The B16s are very popular in E9X and E60 world.
There’s a thread on Vorshlag’s forums where they go step by step with a set of Bilstein coilovers and do the linear spring swap. Pretty interesting and sounds like a compelling option given that Bilstein dampers seem to have great longevity.Originally posted by BottleRocket View PostI'd be very interested if Ohlins R&T were added as an option. Specifically the preassembled kits that 3dmmotorsport sells that include camber plate options and front strut spacers. Maybe you could try reaching out to them and see if they'd be interested in supported a group buy?
Maybe the group buy adds Swift springs at a steep discount too??'03.5 M3 SMG Coupe - Jet Black / Black
Have installed the Bilstein PSS9s (95% exactly like PSS10) on both my E46s. I can’t offer comparison to the Ohlin’s, but the Bilsteins are as described above. Very street compliant on soft setting (and not slammed). Bilstein use “progressive rate” springs in the kit for a compliant ride compared to “linear rate”.Originally posted by T.J. View PostFor what it’s worth my experience is almost opposite. I run pss10 on full soft and find it comparable to stock if not a hair less harsh. The best thing I can say about the kit is that it is incredibly settled. Hit a bump on the freeway and it’s one motion then settled.
Thats a great price. I would sell my PSS9 and buy these new if they weren’t basically the exact same thing.
I’m working on interior trims.Originally posted by freshprince2421 View PostBoth Ohlin's and PSS10 are on my short list, Ohlin's preferred so would love to have that as an option...
Can we get a feeler for Karbonius CF interior trim? They are now NLA so a final group buy could be big!!
I have a test set coming in from Karbonius Monday
Don't treat intervals as fixed. Öhlins is just being more conservative as they assume more track usage. If you street drive your car the interval will be much longer.Originally posted by Epoustouflant View PostI'm not a huge fan of the Ohlins R&T due to their rebuild intervals - but I can see the value. It's a very high quality bit of kit. I haven't reached out to them. If you guys have interest, I can try!
Gesendet von meinem LON-L29 mit Tapatalk
suggested DFV rebuild interval from Ohilns
- 30 hours track driving
- 37k miles street driving
i wouldn't say that's conservative since their track driving spec is a maximum time between rebuilds
not sure how this compares with bilstein since i haven't heard seen any suggested intervals from them officially
fwiw i'm running TCK SAs (they use custom valved konis) with at least 60k mixed driving on them with no issues. i've contacted them directly about potential rebuild and they said dont bother unless there's an obvious leak or degradation in performance.
