Hey guys,
My SMG has started playing up recently. I first noticed it changing up to 3rd gear where it would flash '3' on the cluster but wouldn't go into gear. This was followed by a fairly savage hesitation changing into 3rd and had since developed into 2nd and 3rd and doesn't seem to coincide with changing up gears like I thought it did previously.
Today, it did the normal hesitation/stutter in 2nd but when I pulled up for 3rd it gave me a handful of neutrals and then decided 6th gear was good as well as giving me the transmission warning on the cluster. From that point I could only change down and not up. I had to stop at a set of lights and it reset to 1st, upon taking off it was fine in 1st but skipped 2nd and went straight to 3rd. It continued to keep skipping 2nd on up and down changes until I turned the car off then on and off went back to normal.
Video of issues here: https://youtu.be/nsl9_Zmuros
My initial research is leading me to think it's the gear position sensor, but I'm open to ideas, thoughts or theories. I haven't pulled codes yet because INPA was being a dick, hopefully I'll sort that out tomorrow.
Cheers!
Cheers!
