TC Kline Camber Plates
    Years ago I had my TCK DAs installed, I got different wheels and I want to reduce the amount of negative camber down to 0.
    I took off the strut brace and it appears that some bolts are obstructed by the tower cutout.
    Is there a DIY out there how to adjust the front camber plates?
    Just some old shitty cars.
    Why zero camber? You'd be better off going with zero toe if you're trying to save tires.
    I doubt you'll be able to get to zero camber.
      May end up with outer shoulder wear with 0 camber
        Ok. There was a TCK adjustment DIY on the old forums. I can’t find anything. Does anyone still have it by chance?
          Jack up the wheel, loosen the 3 nuts on strut tower and then move the strut in for more negative camber.
            Easy enough. Thanks.
