Cooling Issue - Street & Track
    What an unlikely culprit. the probability of both the OE rad and the aftermarket both being bad back to back. Glad you found the solution
      Originally posted by bimmer View Post
      Welp, as much as I can't believe it, a brand new BMW OEM radiator fixed the issue. I am pretty shocked that the previous one crapped out after only 1.5 years, but I guess these things happen. Thank god for FCP Euro. Lesson learned on assuming new-ish parts shouldn't be the issue.
      wonder why the 1.5 years young radiator has the issue; no debris or dust covered cooling fins? I can't believe the water channels or pipes in the rad clogged up only 1.5 yrs. Maybe it is just a bad product with too narrow channels from day one and getting worst.
        No dust or debris on the fins, and no physical damage that I could find. I do wonder if it was defective from the get go and getting worse as you suggest. The issue really became apparent after my move from CT —> CO so I wonder if the higher temps and high altitude/thin air were enough to make the defective rad show it’s true colors?
          That's crazy! I wonder if FCP would warranty a CSF radiator for an OE replacement.
            If they sell it, they will
              A properly functioning stock rad in the car is superior to every aftermarket option, IMO.
                FCP let me return the CSF radiator outright after hearing about my issues with it. I then had the new BMW OEM radiator refunded to me as a warranty swap for the one I purchased 1.5 years ago. I love that company.
                  I always love when people state they "upgraded" their radiator with csf haha.
                    Had one put in 3 months ago...still on the fence, wish I knew earlier 😐
                      So you had the full aluminum csf radiator and it still gave the same issue? And the a 2nd oem radiator fixed the problem? That's some really crappy luck getting 2 defective radiators. Glad you finally fixed the issue. Time for more Track Days!
                        I would describe that as a defective OE rad and a CSF rad operating as expected.
                          Correct - my half Irish luck isn't enough apparently 🤷‍♂️ but yes more track days for sure!
                          And yeah - apparently the CSF rads are no bueno. My thought process was that an OEM rad after 1.5 years and < 5000 miles couldn't keep up so an aftermarket surely would be better than that. Wrong.
                            Great to hear, I love them as well!
                              The csf isn't defective, it's just shitty.
