What is the easiest way to disconnect the passenger airbag?
Disconnect Passenger Airbag
I want to have a passenger in the car over the weekend, it is now mostly put together but I have yet to address the airbag recall (I hope to schedule something tomorrow).Originally posted by sapote View PostDisconnect or disable it?
To remove: remove the fake wood trim across the dash, remove the right most air vent, reach in to remove nut/bolt hold the dash cover, then the airbag module is right in sight.
I guess I want to temporarily disable it. What is the easiest way to do that?Just some old shitty cars.
Someone else was asking this on another forum. I don't have my own picture (so excuse the blurriness, because that's just what I found online) but I believe you could just disable the seat occupancy recognition, then it won't go off (circled in red). You could also uncheck IC3 as well I suppose. These are done through PA Soft
I actually think the logic works the other way. If you disable the occupancy sensor then all the airbags will go off in the event of a crash.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 2
